20 Most Recent All Star Forum Star Women's Snowboard Questions & Answers
2answers
Snowboard length calculation
"Your height (inches) x 2.54 x 0.88 = Suggested Board Length Rider Height Range of Board Length 4 Feet 109cm 4'2"" 114 -120cm 4'4"" 115 - 125cm 4.6"" 118 - 135cm 4.8"" 120 - 135cm 4'10"" 125 - 140cm 5 Feet 130 - 142cm 5'2"" 135 - 145cm 5'4"" 140 - 148cm 5.6"" 145 -152cm 5'8"" 147 -155cm 5'10"" 154- 163cm 6'0"" 157-165cm 6'1"" 160-168cm 6'2""+ 159cm or greater"
3/8/2022 10:43:35 AM • All Star Forum... • Answered on Mar 08, 2022
Snowboard type or styles
"There are Three Different Types of Snowboards available on the market today: Freestyle, Freeride (All Mountain), and Alpine (Carving) Boards. Each board has a unique construction technique and materials, shape, flex pattern, and size. The type of Snowboard you ride should correspond to your particular style of riding. Freeride or All Mountain Board Freeride or All Mountain Snowboard Of the three Snowboard types, the Freeride Snowboard is the most popular. Accounting for half of all Snowboard sales, this type of board is a good all-mountain, park and Halfpipe Snowboard that is designed to float well in Powder Surface. You can enjoy carving, catching air, and basically all riding aspects with this type of Snowboard. Freeride boards have a directional shape and are meant to be ridden primarily in one direction. Having a directional shape means that the Snowboard's tip is different from its tail. In freeride, the tail is generally more narrow, shorter, and flatter than the tip of the board. With this, the stance on freeride boards is usually offset toward the tail of the board. Still, freeride boards can be ridden Fakie, despite their directional shape. Freeride Snowboards are usually fairly soft and maneuverable enough for beginners, but stiff enough to hold a fast turn in hard snow. This type of Snowboard bridges the gap between Freestyle and Alpine carving. However, it isn't as stable as a carving board and it isn't as agile as a freestyle board. Freestyle Snowboard Freestyle Snowboard A Freestyle Snowboard is wider, more stable, and more forgiving to ride. Also, it is shorter, lighter and (compared with a freeride board) softer in flex, which makes it easier to turn. These characteristics make a freestyle board very responsive to the rider. Consequently, it is the best choice for the beginner. These boards are built mainly for performing tricks in terrain parks and halfpipes (e.g. spins, air, grabs and riding fakie). Still, Freestyle Snowboards have limited edge grip and stability, and are not good for carving turns or cruising fast. Most Freestyle Snowboards are either twin tip boards or directional-twin. Twin tip boards have a centered stance with a tip and tail that are exact copies of each other, making them symmetrical in shape. Both ends of a freestyle Snowboard have a shovel, and freestyle boards with twin tip design makes it easy for beginners to ride both forward and backward (fakie). Directional-twin Snowboards are similar to the regular twin tip Snowboard; only, its tail is stiffer than the nose. Carving, Alpine, or Race Board Carving or Alpine Snowboard Carving Snowboards are narrower than freestyle and freeride boards. Their long, narrow, stiff constructions are configured for higher speeds and cleaner carved turns. With this, carving boards allow quick edge turns, swift, superior edge-holding power on hard snow, and good stability for speed. Also known as alpine boards, these snowboards almost look like an enlarged Ski. They are made in both symmetrical and asymmetrical styles and tend to only have a shovel on the nose. Similar with freeride boards, carving boards are made to ride only in one direction. While carving boards offer a higher level of performance, they are more difficult for the beginning rider to use and are generally reserved for more advanced riders. Alpine Snowboards are mainly preferred by Snowboard racers for a great day of fresh unridden powder. Keep in mind that alpine Snowboards are configured for riding and carving downhill, not for doing tricks. To summarize, freestyle, freeride, and alpine or carving Snowboards are the three basic types of Snowboards. It is easier to maneuver a soft-flexing, twin-tip, gradual side cut Freestyle Snowboard. On the other hand, it is harder to maneuver a stiffer-flex, directional, aggressive sidecut All-Mountain Snowboard with scores of combinations in between. Always remember that the type of Snowboard you ride should correspond to the type of riding that you like to do, and that both Freestyle and Freeride boards are good Snowboard types for beginning snowboarders."
1/31/2015 12:43:30 PM • All Star Forum... • Answered on Jan 31, 2015
4answers
Snowboard length fit
"Length is one of the most important characteristics of a Snowboard. The length of a Snowboard is measured from the tip of the nose to the end of the tail. The length is usually measured in centimeters and often abbreviated to just the last two digits. Board length varies from 100cm to 180cm. To find the appropriate length for you, start by comparing the board length to your height. Although there are no dead set Rules in Selecting Board Length, the following are several guidelines to get you started. When holding the board on its end: * Short board should reach somewhere between your collar bones and chin. Shorter boards are easier to maneuver, great to be trained on, and often preferred by riders who do a lot of Snowboarding Tricks, park and Pipe Riding. * Medium length should come up between your chin and eyebrows. This length is preferred by all around intermediate to advanced riders who ride a variety of terrain, including parks and steeps. * Long boards should go from your forehead to several inches over the top of your head. Long boards are used for high-speed carving, deep powder snow surface, and big mountain terrain. Choosing the suitable board length is not only influenced by your height but also by your weight. Keep in mind that a Snowboard acts like a leaf spring - it has no clue how tall the person standing on it is. However, it does know your weight. Based on your weight or body structure, the following will help you choose the Right Length of Snowboard: * Lighter people should have shorter, more flexible boards. This is because a lighter person on a longer board commonly has a hard time controlling the board and initiating turns. * For an averagely built person, the board length should reach somewhere between the chin and your nose. * Heavier people should have longer, less flexible boards. A short board isn't advisable for heavy riders because the board often have a tendency to ""wash out"" or perform poorly, especially at higher speeds. * Freestyle riding is often done with a shorter board to allow better maneuverability. * Freeriding, deep snow, and racing boards will be longer in size. * For riders who are into Backcountry Snowboarding, go longer for stability. You may also consider your aggressive or timid style. If you're the type of boarder who really attacks the hill, you'll want to increase the length of your Snowboard up to five centimeters from the average size. Then again, if your riding style is naturally slower in character, go down five centimeters. Still, keep in mind that one Snowboard doesn't do it all."
8/28/2010 1:40:44 PM • All Star Forum... • Answered on Aug 28, 2010
I am 5
prob a 142 board...but use this site - awesome calculator that will size a board for you just by putting in some info
http://www.frostyrider.com/tips/size-guide.htm
hope this helps - good luck!
9/26/2009 12:27:33 AM • All Star Forum... • Answered on Sep 26, 2009
What does the number mean in the base measurement of snowboards?
It is the type of sintered base used on the board - the higher numbers indicate higher density and pressure used to make the base material - the better base will have more "pores" and will hold the wax better resulting in a faster board
12/1/2008 1:20:43 PM • All Star Forum... • Answered on Dec 01, 2008
Snowboarding skill level
In Snowboarding, the skill level is divided into three types: * Newbie - from total beginner to having a few days of riding experience * Intermediate - comfortable with common riding techniques and starting to try tricks * Advanced - comfortable with riding all pistes and off slope; advanced tricks and skills"
12/1/2008 1:20:42 PM • All Star Forum... • Answered on Dec 01, 2008
I for got my email password and also myalternative
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 12:38:28 AM • All Star Winter... • Answered on Aug 13, 2010
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski Doo. Where can I get a repair manual?
Try contacting Ski Doo directly to inquire.
1/23/2021 8:50:35 PM • Winter Sports • Answered on Jan 23, 2021
All Star Forum Star Women's Snowboard Logo
9 questions posted
Top All Star Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you an All Star Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
  • All Star Winter Sports
Most Popular Question
number mean in base measurement snowboar
  • Winter Sports
