20 Most Recent
Kenmore 54501 Dehumidifier Questions & Answers
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
I cannot change the set
The problem is, your trying to raise the humidity level, not lowering. These work in reverse of what you may think. Lower the level (Arrow Down) to 32% and it will continue to run, but will draw more humidity out of the air and will not stop until the water collection bucket is full or the humidity level reaches 32% or you turn it OFF.
When you pushed the Arrow Up Button, it was already on 70%, that's as high as it will go. But that means, you're trying to maintain a 70% humidity level. If it's Summer where you are, I don't think that's what you want.
Hope this helped you. Please let me know. Thanks.
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
No water draining from new kenmore dehumidifier
were all the packing materials removed from inside unit before start up , lots of times one misses a small piece of tape they add at factory to catch bucket , to keep it in place during shipping , this will prevent the unit from working as it makes control box think there's no bucket in place to catch water
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Compressor not working
ck your setting on control panel sometimes they get changed , also ck that your catch bucket is fully installed sensors are there that keep it from running if it does not have a bucket installed
Unit only runs when set to 1 cnt
unit runs If set to continuous mode only ? the other settings are a time off function that lets unit run only a portion of day , saves energy
Why is it rattling now , and how can i fix it?
noisey machines is a very common complaint I hear , most times it comes from being placed on a non level floor , and only two or three of the four legs are touching the floor , this makes it go off balance , second on units that run for greater than a year , they pick up build up on there fans and this makes it Micro wobble , fans can be removed and cleaned and legs can be shimmed to touch floor
Freezes up
most units draw in the front and expel from the rear air , keeping filters clean (never run without one) is important for this function , frost on coils is a sure sign that air flow is low , or might be unit has lost [part of its gas charge due to heat build up from loss of cooling
How can you tell if the compressor in the dehumidifier is working?
listen for it , compressors have a distinct sound of tiny rocks hitting a pan (that not what's really going on in there ) that fans don't have
most units have a timer function that makes u wait for compressor to come on long after fan starts , so u might have to listen for up to fifteen minutes for it
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
