20 Most Recent Burton Ak Cyclic 2L Snowboard Jacket Red Rock Questions & Answers
Can't find the Burton AK 2L Cyclic Snowboard
Some missions are better left unfulfilled.
6/11/2010 6:49:27 AM • Burton Ak Cyclic... • Answered on Jun 11, 2010
Hello, I recently bought some Burton Custom EST
take it back theyll give ya another mount it happens when there mass manufactured
6/16/2011 2:49:24 AM • Burton Winter... • Answered on Jun 16, 2011
I recently bought a Blunt
The threaded inserts are built into the layers of the snowboard so they can not come out while riding. Imagine if they were able to be pulled out and one came out while you were riding - your boot and binding would lift right off the snowboard. You can try to fix the threads with a tap (threading tool), but otherwise they will not be able to be fixed and you would have to get a new board. If you just bought the board, you could try contacting Burton about having it replaced.
3/8/2011 3:09:01 AM • Burton Winter... • Answered on Mar 08, 2011
How can i put new threaded inserts into my
These are called "T-Bolts" in teh industry and need to be installed by a good repair shop to last any reasonable length of time.
6/8/2010 8:23:01 AM • Burton Winter... • Answered on Jun 08, 2010
My Burton boots are loose around the ankle and the
For the ankle you may need some specially shaped foam inserted between the boot outer and the liner to take up the space. This can be done at any good snow store. As for the laces make sure that when lace up in the morning lace the boots all the way to the top and when you reach the top, while holding the laces, flex in the boot a few times and kick your heel against the ground to make your your foot in snug (this may also help issue #1. Once you have done this, pull up hard again on the laces and loop them once around the top before tying a double knot.
6/8/2010 3:24:33 AM • Burton Winter... • Answered on Jun 08, 2010
Boy just got a burton hero board, put on his danny
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
6/8/2010 3:11:56 AM • Burton Winter... • Answered on Jun 08, 2010
Broken cable on BOA lace system on snowboard boots
i just recieved a new lacing for my Rocky revolver boots... there is a little tool to loosen the set screw in the knob...works like a charm.
3/17/2010 8:00:08 PM • Burton Winter... • Answered on Mar 17, 2010
Burton bag failed
I doubt it.. At 15 years old it's had a good life.. Time for a new one..
10/9/2009 12:30:51 PM • Burton Winter... • Answered on Oct 09, 2009
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski Doo. Where can I get a repair manual?
Try contacting Ski Doo directly to inquire.
1/23/2021 8:50:35 PM • Winter Sports • Answered on Jan 23, 2021
Burton Ak Cyclic 2L Snowboard Jacket Red Rock Logo
1 questions posted
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
  • Burton Winter Sports
Most Popular Question
find burton ak 2l cyclic snowboard
  • Winter Sports
