20 Most Recent Microsoft Surface Pro Questions & Answers
www.windowscentral.com/using-amazon-echo-windows-10
You cannot install the application but you can control it through your browser
Microsoft... | Answered on Oct 28, 2018
  1. Double check outgoing configuration mail setting
  2. uninstall mail & re-install it again
Microsoft... | Answered on May 19, 2016
contact facebook tech support
Microsoft... | Answered on Apr 08, 2015
Try clearing the history and cache on the browser.
Make sure the location and keyboard information in the control panel is correct.
Microsoft... | Answered on Mar 23, 2015
Control Panel. Accounts will show all accounts on the machine.
25591863-qztzwsd5tae24twsq5kxbvm0-5-0.jpg Typing lusrmgr.msc at the run prompt will reveal the systems administrators account panel which gives you access to users and groups.
User profiles are available from the System properties panel.
25591863-qztzwsd5tae24twsq5kxbvm0-3-0.jpg In here you can identify or delete user profiles.
Microsoft... | Answered on Mar 20, 2015
There are no surface pro 4's or 5's yet unless you are an engineer at Intel. If you want it to stop discharging so quickly- turn it off, and no I don't just mean put it in standby. You need to power it off completely- that way you will keep it from eating your battery when not in use. These things boot so fast that the inconvenience of 15 seconds is not worth the hassle of a dead battery coming out of sleep after a day or so.
Microsoft... | Answered on Feb 18, 2015
Please explain- do you mean that nothing happens when you push the power button? Does it show anything at all then go black with the windows button vibrating being the only thing? Is there any error message? Please clarify.
Microsoft... | Answered on Oct 02, 2014
These get stuck- try holding the power button and the volume up for about 10-15 seconds and it should reset itself.
Microsoft... | Answered on Sep 07, 2014
Check your manual or search on Microsoft forum to see how you can stop the change. Unfortunately with the apps, this is dependant on Microsoft releasing software/apps that work on the tablet.
Microsoft... | Answered on May 05, 2014
You should have had in the box with your Surface 3 Tablet a charger. It will have a plug with 2 points that is for your power plug, and at the other end you will have a natty little flat magnetised plug for the side of your Tablet. Mine is at the bottom right slot, looking at the screen of your Tablet. Now when the power is turned on, a small bright light will glow. That is now informing you that the battery in your Surface is being charged. Now at the bottom right of your Task bar, that is the Bar on the bottom of your screen where you can place program short cut Icons for your convenience. Now the speaker Icon which is there toward the right-hand side and has a cross if off, or a different look when on. Now the next icon on its right is the one that tells you how much charge is in the battery, if you touch it, it will come on to the screen informing you how much charge you have in the battery. If I'm using my Surface a lot and I do I keep it on charge while I work as a precaution to keeping my Surface well topped up. Hope this helps.
Microsoft... | Answered on Mar 12, 2019
Hi, you may have to go to the Microsoft home site, and ask for Microsoft Word or Office for iPad. There is one for both Apple and Android systems, but it is a little different to the one they have in their own Windows system. I use Open Source from Oracle it's free and it works well in my Windows 10 machine and Surface Tablet. Best of luck.
Microsoft... | Answered on Jan 13, 2019
-Make sure not authorize public access in your computer then you're safe.
Good luck
Mai
Microsoft... | Answered on Jun 12, 2018
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
Microsoft... | Answered on May 20, 2018
Microsoft Surface Pro Logo
22 questions posted
Top Microsoft Tablets & eReaders Experts
Ekse
Harrie
Ruben Caraballo
Ruben Caraballo
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Tablets & eReaders
Most Popular Question
when send email gmail goes outbox will
  • Tablets & eReaders
