20 Most Recent
Jura Capresso Impressa F7 Espresso Machine Questions & Answers
When turned on it will prompt "Open Tap" "Close Tab"
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
Error message Fault 5
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
