20 Most Recent Xterra Fitness Xterra Treadmill Questions & Answers
i have the same problem
Xterra Fitness... | Answered on Jan 15, 2017
I have the same problem... It doesnt work.
Xterra Fitness... | Answered on Jan 22, 2015
New xterra trendmill will not start says error 5 help
Xterra Fitness... | Answered on Dec 29, 2014
Google (Freespirit)(903)(manual) without parens.
Exercise &... | Answered Yesterday
No. Mine isn't.
Exercise &... | Answered on Feb 13, 2020
First it always helps to post a make, model and serial when you can. You have what is called a serious safety issue. As a field tech theb1st thing I would tell you is dont use it until it fixed. Then I would say call the manufacturer and order a new safety key assembly switch. They vary about from unit to unit but all do the same thing" cut power when the key is pulled. Doeant matter if its magnetic or manual. But since I just mentioned it...if it's a magnetic switch then the magnet may have come unglued from the key. Look for it...it may be that simple.
Lastly, worst case, depending on what unit it is, it could be either upper or lower board. Some are handled in the brain (upper board) and some go straight to the brawn (lower board).
Anyway...keep it simple. Stay off it until ita fixed. Look for a magnet that's come loose. Call the manufacturer for parts if you're so inclined. And...did I mention. . .dont use it?
Exercise &... | Answered on Feb 09, 2020
How to pair your Fitbit to your iPhone or iPad
  1. Tap the account button in the upper-right corner of the Fitbit app.
  2. Tap Set Up a Device.
  3. Select the Fitbit you want to pair from the available list.
  4. Plug your Fitbit into its charger.
  5. Tap Next.
More items...
Dec 25, 2019 www.imore.com > how-set-and-start-using-fitbit-iphone-and-ipad
How to set up and start using Fitbit for iPhone and iPad ' iMore
Exercise &... | Answered on Feb 03, 2020
Sounds like an upper board because of the display issues, but a lower board because of the lack of compliance, error recognition, and start up.
Run continuity on the main wire harness leading to the console.
If the harness checks out, check the motor for functionality with a low voltage battery.
You can start with the lower control board, check out fitnessrepairparts.com for your specific model
Exercise &... | Answered on Jan 29, 2020
Xterra Fitness Xterra Treadmill Logo
Popular Tags
8 questions posted
Top Xterra Fitness Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Xterra Fitness Exercise & Fitness
Most Popular Question
error 6 message xterra 3 0 treadmill
  • Exercise & Fitness
