20 Most Recent
ASUS VivoTab RT Questions & Answers
How can i get android apps in my tabet
a rt tablet is NOT a android tablet. it runs a leaner windows based live tile system called windows 8 rt. you cannot get pure android applications on the asus but you developers will port applications over to other operating systems so you may be able to get a different version or something simlar on that kind of tablet if the developer made it.
HOW I FIXMY VIVORT
Hi, This is a problem in the BIOS my advice to you is get in touch straight away as you will always have problems! unless they are prepared to walk you through the settings in the BIOS. Be a happy PC owner & get this exchanged free of everything they should exchange the PC without any problems & they will pick up the present PC when they deliver the new one to you. I must add the blue screen is another problem with the Video card, Hence stick out for an exchanged PC it's their liability. Please leave me feed back: Malcolm Campbell, Thanks.
Shaking screen and phantom clicks
I would recommend that you contact Asus directly for additional support. It sounds like there's a hardware malfunction, which may require repairs.
Tablet gets blocked everytime it enters in sleep
80% of windows 8 issues are resolved by installing the lastest windows updates.
- Slide from the ride side of the screen to bring up the charms bar.
- Select "settings" charm
- Click "PC settings" on bottom left.
- Scroll to the buttom, and click "windows update"
- Click "check for updates, and or install all available updates.
- Profit!
Serial number on a asus vivo tab rt
- Turn on your tablet- Go in "desktop mode"- In the "search bar" (swipe outside right to inside going left, tap "Search")- Type "run" and tap the "Run" app icon- In the textbox of the "run app", type "cmd" then tap "Ok"- Type "wmic bios get serialnumber" in the command prompt- Serial number will appearThere is also a sticker at the back of the tablet containing the serial number (bottom left). This number should match the one obtained from the wmic command.
