20 Most Recent
Hobart H600 Stand Mixer Questions & Answers
How old is my H660T mixer
this mixer came out of a pizza hut in illnois, looks like the manufacture date is june 1994, dont forget to vote, hope this helps, monomoy
How to change oil in 20 quart hobart mixer and the
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
How do you change or add oil to a Hobart H600
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
HELO I recently purchase a
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
How much oil does my H 600 Mixer hold ( Hobart in the Transmission
1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
Hope that helps!
