20 Most Recent
Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves - Questions & Answers
Ice maker not working on a whirlpool french door fridge
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
4/1/2015 11:09:24 AM •
Whirlpool...
Answered
on Apr 01, 2015
How does to defoze refrigerator
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
3/3/2015 4:27:50 AM •
Whirlpool...
Answered
on Mar 03, 2015
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
8/19/2014 12:27:28 AM •
Whirlpool...
Answered
on Aug 19, 2014
I don know how to turn on the ice maker of a
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
8/7/2013 12:56:08 AM •
Whirlpool...
Answered
on Aug 07, 2013
I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions?
[email protected]
10/7/2023 6:12:17 AM •
Whirlpool...
Answered
on Oct 07, 2023
