20 Most Recent Fossil AM3784 Wrist Watch Questions & Answers
0answers
Battary size for fossil blue
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
8/27/2010 3:13:55 AM • Fossil AM3784... • Answered on Aug 27, 2010
To set the time on the 3258.
mcdevito75 here, Generally, you need only worry about 2 buttons, MODE and SET. ----- Simply press the MODE button ususally on the right side of the dial on the watches caseing, see the display blinking now press set ususlly on the left side on the caseing, press set to adjust the functions, (hour, minute etc.) pressing mode after each function is set. When done press MODE again to see steady display. If by chance there is no MODE button, the MODE button may be a dimple on the caseing you can push in with a pin.
7/10/2010 7:02:02 PM • Fossil AM3784... • Answered on Jul 10, 2010
Setting m/d/s
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals. Rate me, please .
4/2/2010 3:43:59 AM • Fossil AM3784... • Answered on Apr 02, 2010
2 months after it was purchased I placed it on its
It should still be under warranty.
Go to Fossil.com and send it to your nearest service center (with proof of purchase).
They should fix it for you.
3/7/2010 6:59:54 PM • Fossil AM3784... • Answered on Mar 07, 2010
My Fossil watch worked when I took it off, it just
Check that the battery is in the correct way up.
Try cleaning the battery with surgical spirit.
If these steps fail, take it to a watch shop.
If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
2/14/2010 6:20:31 PM • Fossil AM3784... • Answered on Feb 14, 2010
How do you make the watch smaller?
Your question is unclear.
Please be more descriptive in your request.
adding a why of the failure is would be quite useful in answering your question.
RECOMENDATION: with information at hand.
Purchase a smaller watch.
Hope this tip helps.
r/
David
2/12/2010 2:40:54 AM • Fossil AM3784... • Answered on Feb 12, 2010
Replace a band on a fossil watch brand 2753 georgia bulldogs
Bands are held to the watch body by springpins. To disengage them, I use a fine blade knife, and pull one end of the pin down by causing the blade to bite into the metal of the pin, between the eye of the band and the watch body. This method will work when dealing with leather straps, perhaps not with a metal band, depending on how much clearance there is between the watch fork and the band's eye.
If there is no clearance, it may be necessary to destroy the springpin to get the band free. Replacement pins can be purchased at a watch repairer.
Replacing batteries: You need the back off. Some screw on, most press in. Press- ins can usually be released with a knife blade, or small leverage device if there is a specific release place on the rear cover. On odd occasions, it becomes necessary to "use a hammer and chisel". Not easy.
Screw- off backs need a tool to engage the slots on the rear. Sometimes can be done with a pair of long- nose pliers.
The backs often have a fine rubber sealing ring, for water resistance.This needs to be put back in place carefully.
The batteries are held in place by various means, spring tension, clamping etc. Sometimes a screw or two must be loosened to free the battery.
Really, it is all a job for the experienced.
I only do work on my own and other family member's watches. I have a range of tools I have made for these. I wouldn't risk doing outsiders' watches. I do bands and batteries, but leave it at that.
5/31/2008 11:05:01 AM • Fossil AM3784... • Answered on May 31, 2008
0answers
0answers
0answers
0answers
0answers
0answers
Fossil AM3784 Wrist Watch Logo
16 questions posted
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
View Most Popular
AM Fossil
  • AM Fossil
Most Popular Question
setting m d s
  • Watches
