20 Most Recent
Fossil FS2919 Wrist Watch Questions & Answers
I have model fs-2919 would
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
I need to remove links
There is usually a pin to take out either in the front closest to the time or down alittle ways . To pop it out use a tint needle or a paper clip.
I need instructions on removing
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
How to sethour and minute
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Best regards. Jewel
I have a Fossil Arkitekt
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
