20 Most Recent 350i5 Car Security System Questions & Answers
Setting for sensor sensitivity in high, just have to change it to lower setting. Or if the shock sensor is close to any exterior panels, it will receive the excessive vibrations.
350i5 Car... | Answered on Jul 04, 2010
you should be able to get a replacement remote from the manufacturer. the remotes are code specific and without the remote the alarm will not go into bypass mode. the remote would be a cheaper route to go than to replace the whole unit. now if the unit is obsolete than the only alternative is to replace with a more updated version or a different brand all together. when you contact the manufacturer you will need model and serial number of the unit this will help them send you the right remote for it
350i5 Car... | Answered on May 17, 2009
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered 5 hours ago
same as jupiter all good
Vehicle Parts &... | Answered on Nov 08, 2019
Don't click on spammer Victoria Archer, as FIXYA doesn't remove most spammers automatically. Volunteers answer questions without charge.
https://www.scorpionauto.com/car-remote-alarm-immobiliser-scorpion-sa30/
Contact information.
https://www.scorpionauto.com/contact/
Vehicle Parts &... | Answered on Oct 25, 2019
Tip
Longer lasting engine maintenance
Your engine will last a lot longer as far as the main engine components if you 1)change your engine oil at vehicle recommended mfg intervals.TIP: if you live in hot climates you should change your oil more often and at less miles .2500 to 3000 ml. every 3 months because the climate the hot temperatures break down oil viscosity at a higher rate thus needed more frequent oil changes for the best engine engine lasting performance.2) always use the recommended weight example (5/30w)TIP: Also for best results the recommended rating of the oil for example on the back of the oil bottle is a rating 2 or 3 letters in a circle .Older vehicles use a different rating than newer vehicles and some times they are not interchangeable this information should be available at your local parts store.3)TIP;: Always use the recommended (brand) oil filter.With the way cars are now especially ones with overhead cams and chains ,aftermarket filters might not supply the same pressure aspects of the original oil filter, So as far to have less or more pressure than that is needed to maintain these components correctly with the correct pressure.
Thanks hope this helps
on Oct 22, 2019 | Vehicle Parts & Accessories
check compression
Vehicle Parts &... | Answered on Oct 14, 2019
if you lost all compression on all cylinders at the same time check your timing belt or timing chain. good luck .
Vehicle Parts &... | Answered on Oct 09, 2019
It is suitable for a number of vehicles, as it includes long bays for vans, and short bays for other vehicles, and with minimal alterations it is suitable for installation in any vehicle model.
It offers more storage capacity for odd sized items, and represents easy inventory control, by reducing the need for overstocking expensive items in your work vehicle.
The system is fully adjustable.
Vertical adjustments can be made to gain maximum use of your vehicle height, while horizontal adjustments can follow the contour of your van, to allow for more aisle space.
The rak-a-van system provides maximum working space and fast access to all items, and optimises productivity.
Tradesman Fitouts 4WD Sydney
Vehicle Parts &... | Answered on Sep 26, 2019
Vehicle Accessories is the leading discount store for automobile accessories. We offers you various cars and bike accessories such as tyre and wheel, replacement parts, auto spare parts , vehicle exterior and interior care services from the best brands at the most affordable rates. The company offers a wide selection of car products, including auto electronics, cleaning materials, oils and fluids.
Vehicle Accessories is an online store that offers all the latest in car parts and accessories at reasonable prices. You can find everything you need to customize your car to make it truly your own.
This Vehicle accessories shop online sells everything under the sun to deck out your car in the best way that fits your needs. If you're getting ready for the summer, you can find all the essentials like waterproof seat protectors, connectors and cables to connect your kayak or surfboard to your car, and bike racks so that you can get out and enjoy the fresh air.
Vehicle Accessories has several locations in Australia where you can buy accessories and products for your car in addition to a full range of services to keep it running at top performance.
Car Accessories Sydney
Looking for the best vehicle accessories installers from Melbourne Contact Local Mechanics Melbourne for better results.Local Mechanics are one of the premier auto repairer groups bringing together customers and their local mechanics across Australia. All mechanical services are performed by highly qualified and licensed mechanics.
Most likely the receiver antenna is defect.
Try see if it is there and is connected correctly.
Off course you have checked the transmitter battery is full!
Vehicle Parts &... | Answered on Sep 25, 2019
get some super lube. pull the cover all the way out and lube the mechinsum
Vehicle Parts &... | Answered on Sep 20, 2019
should be on the tail of tranny left side
Vehicle Parts &... | Answered on Aug 16, 2019
You need to register with snooper to download the updates(even if previous owner has done so) or else you can ask him his user id and password
Vehicle Parts &... | Answered on Aug 14, 2019
350i5 Car Security System Logo
Popular Tags
6 questions posted
Top Crime Guard Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Crime Guard Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Crime Guard Vehicle Parts & Accessories
Most Popular Question
alarm activate itself every time
  • Vehicle Parts & Accessories
