20 Most Recent
Straight Talk LG L40G Cell Phone Questions & Answers
How do i transfer contacts list from straight talk phone to straight talk phone phone
sync contacts with google when you sign in on new phone all contacts will be imported. The other way that works is an app called jsbackup get it from google play its free it will back up everything apps text messages contacts then transfer the back up file to your sd card put that card in new phone re download jsbackup and click install from back up only take a few seconds and its done you will have to reinstall the apps though but everything else is automatic hope that helps
I am having trouble connecting to internet even when 3g available for several days
under 'settings' -'more' - 'mobile networks' - 'access point names' hit menu key on bottom right of phone then 'new apn' under name enter STRAIGHT_TALK, under apn enter tfdata, scroll down to MMSC and enter
http://mms-tf.net, then in MMS proxy enter mms3.tracfone.com, and under MMS port enter the number 80. hit menu key and select save. then return to access points and click on the button to the right of STRAIGHT-TALK.
thats how to fix it i had to do it i got that from straight talk forum
Lgl40g straight talk phone will turn on but only
try this Recovery
Solution
Factory data
reset
How do I perform a
Factory data reset?
Resetting the phone does not erase
any system software updates you have
downloaded or any files on your microSD
card or internal memory, such as music
or photos. And so, if you want to erase
all the data on the internal memory while
resetting the phone, select the check box
of Erase internal memory.
Recovery
Solution
Hard Reset
(Factory Reset)
How can I perform a
factory reset if I can't
access the phone's
setting menu?
How to perform a Hard Reset (Factory Reset):
1. Turn the power off.
2. When the phone is switched off, press and
hold the Volume down key + Home key
with your left hand. Then press the Power
key while pressing Volume down key +
Home key.
3. LG logo would be displayed in 1~2
seconds then the phone would re-boot
showing android robot animation. Finally
the factory reset would be processed.
Attention:
If a factory reset is performed, all
installed applications and user data will
be erased. Please remember to back up
any important data before performing a
factory reset.
Wats the puk code
This is **** with the lg gw620 i cant receive or transfer files through bluetooth. The touch screen is always a problem. Most often it cant touch or the touch not working. **** this lg phone . ****
What is the master reset code for a LG Optimus when locked
To Reset a LG Optimus Zone that is locked.
- Press and hold the Power button.
- On the device screen, select Power off.
- Press and hold the Volume Down, Home, and the Power button simultaneously until the reset screen appears.
- The device will automatically initiate a factory reset.
