20 Most Recent
Sony xperia j st26i black unlocked gsm phone Questions & Answers
Unlock password
You will have to reset it factory settings
Performing factory data reset ( master reset or hard reset )
Sony Xperia J ST26i/ST26a via Settings menu:
To perform a factory data reset
From your Home screen, tap Applications
tap
Settings
tap Backup
& reset
tap
Factory data reset
tap Reset
phone.
tap Erase
everything.
Sony xperia troubleshooting
You probably need to provide a few more details than this. Have you tried to turn it on and it won't turn on, or is it simply that you don't know how?
If it is that you don't know how, go to your settings, then in wireless, click on bluetooth and enable it.
Have you wiped the phone and started over, it should pull the new number when it provisions to the network. Your carrier may be able to help, I would ask them why it is stuck ESPECIALLY if the phone is usable but shows the old number, if that is the case, the carrier has to reprovision (reset their network tower communication with the phone).
Troubleshooting also differs between CDMA and GSM slightly, the best bet is to erase the phone if you have already talked to the carrier..
Sony xperia j manual
Where were the pictures before the loss, were they perhaps stored in the cloud? There are a lot of Sony people saying the same as you are which is the pics disappeared so logically they must be going somewhere, hopefully to a cloud source.
Why are my pictures and songs gone
Gone as in where were they stored in the first place? If stored on the device memory card, they may still be there, download a file manager and search them out. If in the cloud, resync with the app like google music, sign out, sign back in via hangouts. Your question is kinda vague as we don't know where you stored the music in the first place to help undo what was done.
My xperia J is hard locked
If your xperia j is hard locked then rush it to your nearest service centre. Only they can unlock it.
thank you
Sim unlock
You can unlock Sim from Sony Xperia J easily by using an unlock code.You can get this code at low cost from
MobileUnlockSolutions.com with easy step by step unlocking instructions.This is the safe,fast and permanent unlocking method.
