20 Most Recent
Haier XQG50-QF802 Front Load Washer Questions & Answers
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
see this causes and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet
valve cold water side may have failed. Most washers have a cold water
rinse and so if they can't fill with cold water they just sit
indefinitely waiting for the cold water to enter. If there is cold water
to the water inlet valve and the cold water works in other parts of the
cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main
control board might be defective. This is not common. Check other causes
first such as the lid or door switch and other components. Timer
If the washer stops mid cycle the timer might
be defective. This part is often misdiagnosed, check other components
before replacing this timer.
10/1/2012 5:08:01 AM •
Haier...
Answered
on Oct 01, 2012
The drum is broken. legs (3) are broken in
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares or spares sources, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
10/7/2011 6:52:16 PM •
Haier...
Answered
on Oct 07, 2011
Model sxqg50-6006 drum does not
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
John C
7/15/2011 11:19:52 AM •
Haier...
Answered
on Jul 15, 2011
Err2. Water not draining. Can I do anything
Their are only a few things that would keep your water from draining. The two most common are a clogged drain filter inside the washer or a faulty pump/motor. With any luck it is just a clogged filter. Refer to your Owner's Manual if you still have it to see about the steps in cleaning the drain filter. If you do not have your manual you will need to gain access inside your washer's cabinet. There you should see a drain filter ensamble where you can remove it, empty the filter out and replace it. WARNING! Be sure to bail out the water in your tub b efore removing the drain so the water does not come out when you remove the drain filter or you will get a big mess. Some models may have a water shut off next to the drain filter, if so, you can simply turn off the valve rather than hand bailing the water out.
11/25/2010 1:51:20 PM •
Haier...
Answered
on Nov 25, 2010
The machine doesn't dry the clothes proberly.
If your
dryer is not drying like it once did or if you just have nottaken the time to give yourself a
clean dryer in a long time then youneed to do that. At least once a year the
dryer cleaning should takeplace.
Lint build up in the
dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about
DryerMaintenanceheatman101
10/30/2010 4:55:39 PM •
Haier...
Answered
on Oct 30, 2010
Haier 1260k error message no 7
Hi
Err 7 is a motor error. You can reset the error by first unplugging the washer and then try and follow the given procedure to resolve error 7 --
- Disconnect the machine from power supply and stop the water supply as well.
- Access the back of the machine by pulling it under the counter.
- Now you’ll be able to see Phillips screws at the back panel, remove them to access the small back plate.
- Now from that opening you’ll be able to see motor and motor connector. Plug the connector back on to the motor if it is unplugged or loose. There is only way to fix it so you will not get wrong.
- Now reconnect the machine with the water supply and plug it into the power supply.
- Select only the quick wash cycle to test the machine.
After this if the error is not resolved then its an issue with the motor, and yu'll need to get it checked from a service tech.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
10/11/2010 6:35:19 PM •
Haier...
Answered
on Oct 11, 2010
It's keep the water inside what do I have to do ??
It could be a clogged hose or pump.. A clogged hose is easier to deal with.. under the sink and washer remove one end of the hose and see if it is holding water and clogged.. If so - let the water drain and blow into hose attempting to free it up.. If its the pump - and you are not spuer "handy" you might have to call in a technician..
Good luck ;)
10/7/2010 7:47:51 PM •
Haier...
Answered
on Oct 07, 2010
My drum has become very
When my washer did that, I found that the shocks that hold the tub were bad...Check out this tip I wrote about the noise and vibration that front load washers can make..Washer Problems Washer noise when spinning
heatman101
9/30/2010 11:29:48 AM •
Haier...
Answered
on Sep 30, 2010
Spin cycle
Remove and repair the Spin Switch located under the lid. The body of the switch had come apart somewhat. I removed the Switch by removing two screws. I put some Super Glue in the seams where it was suppose to fasten and held it for a while and remounted the switch and it works fine. I hope this helps. Before working on it be sure to unplug the machine.
JP Banks
11/13/2008 10:19:18 AM •
Haier...
Answered
on Nov 13, 2008
I need to replace the bearing--how do I get it off??
I have the same problem, repair guy came and said that the main bearing is permanently fixed to the outer tub, so it all needs replacement. I have read horrible reviews about this problem, my machine is only two years old and I'm thinking that I am going to toss it instead of fixing it!
6/20/2007 6:06:49 PM •
Haier...
Answered
on Jun 20, 2007
