20 Most Recent Haier XQB60-91AF Top Load Washer Questions & Answers
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
3/15/2014 11:18:37 AM • Haier XQB60-91AF... • Answered on Mar 15, 2014
Haier -XQB55-10
Either your inlet hose is blocked or your filter screens on hose as well as machine are clogged. Carefully unscrew to examine and clean out, refit carefully.
2/23/2009 5:59:42 AM • Haier XQB60-91AF... • Answered on Feb 23, 2009
I have a Haier washing machine and the door is locked. I tried washing a blanket and now I can't get the door open. Help!
try unplug the washer an waiting 5 min it should unlock if , if ti does onlock you made need call a appliance servce tech
4/7/2024 3:17:00 AM • Haier Washing... • Answered on Apr 07, 2024
2answers
Manual de usuario lavadora Vince XQB22-19
English only on this North American Fixya please. Vince XQB22-19 washing machine user manual. It does not work. https://www.google.com/search?q=%E2%80%8BVince+XQB22-19+washing+machine+user+manual ..
2/14/2024 11:28:31 PM • Haier Washing... • Answered on Feb 14, 2024
Haier Washing Machine It has error code Fb?
Question edited for clarity. Question moved from Firearm Optics category. It looks like you solved it yourself as to what is means https://www.manualslib.com/manual/1197834/Haier-Hw80-B14266a-Ec.html?page=21 More here, but no one gives the reason. https://www.google.com/search?q=haier+HW80+washing+machine+error+code+Fb Model number appears to be incorrect as 'PD1626'? https://www.google.com/search?q=HW80+PD1626 ..
2/6/2024 5:11:38 AM • Haier Washing... • Answered on Feb 06, 2024
My Haier 18 dishwashers control panel does not illuminate.
First, confirm that the dishwasher display is working. If the display is still working, try pressing some of the touchpad buttons. If some of the buttons respond correctly but others don't, it is likely that the touchpad is at fault. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
12/10/2023 12:39:38 PM • Haier Washing... • Answered on Dec 10, 2023
Haier HLP21N Pulsator 1-Cubic-Foot Portable Washer. Why won't it completely drain?
Question edited for clarity. My guess is that your drain hose is too high. The pump is in the base of the washer and pushes the water up the tube and into the drain/ when the pump stops, the residual water in the hose drops back into the base of the machine, so the higher the hose, the greater the column of water. https://www.manualslib.com/manual/837407/Haier-Hlp21n.html?page=10#manual Or The Drain Pump is blocked or failing. ..
10/12/2023 2:32:30 AM • Haier Washing... • Answered on Oct 12, 2023
Screw to pulsator won't stay in my portable washing machine Haier
Are You Looking For a Best Mobile. <a href="https://watmobile.com/">Whatmobile</a> Will Help You To Find mobiles with all specification. Latest Mobile Prices in Pakistan.
6/16/2023 1:12:40 PM • Haier Washing... • Answered on Jun 16, 2023
Haier HLC1700AXW not drying
this could possibly help.... https://www.youtube.com/watch?v=D2jYHVzu0Sg
3/9/2023 12:54:17 AM • Haier Washing... • Answered on Mar 09, 2023
Haier Washing Machines Temperature sensor error, can I fix this myself?
The first thing to do is to clean the machine following the manufacturer's directions in the owner's manual. I've seen a number of washing machines that generated fault codes because lint or other muck gummed up a sensor; the cleaning process often is enough to take care of the problem. In the U. S., we have a product called CLR (Calcium, Lime and Rust remover) that does a nice job of cleaning out washing machines. I think the primary ingredient is dilute citric acid. Some manufacturers recommend chlorine bleach - go with what is in the manual first. If the cleaning process doesn't eliminate the error code, yes, you probably still can fix the washer, if you can open it. If you know the model number, you may even be able to obtain a service manual that will tell you what to look for. Warning: unplug the machine before removing any covers. Exposed electrical terminals are a shock hazard if the machine is plugged in. Some appliances have a wiring diagram attached inside, or on a service sheet stored inside the control panel. If you find it, the wires going to the temperature sensor will be identified by the colors. For example, a YEL/BLK wire is yellow with a black stripe. You can trace these wires to find and identify the temperature sensor. Once you find the sensor (it will be somewhere in contact with the wash water, probably on or near the tub), inspect the electrical connections at the sensor and at the control unit, and clean up or repair any corroded connections. Check the wiring to make sure it hasn't been pinched between parts and damaged. If the wiring looks good, take the sensor out and remove any muck that is built up on it. Be sure to wipe clean the gasket or o-ring, and any sealing surfaces in contact with the gasket. Re-install, put the machine back together (being careful not to pinch any wires between parts or panels!) and test it. If you still get the error, you may have to replace either the sensor or the controller.
11/29/2022 12:11:38 AM • Haier Washing... • Answered on Nov 29, 2022
What's causing a Haier HLP24E mini washer to keep throwing a UL unbalanced load error code right before spin cycle?
Take the 4 screws out of the top section, lift up the whole top. You will see a bar. You must lift the top so the bar raises above the drum. Take the screws out of the plastic cover and check the bar .it has 2 round ends that rest in two holes. If it came out of one simply place it back in the hole. You will hear it click when pressing it. Put back together. Problem solved.
11/27/2022 2:46:59 AM • Haier Washing... • Answered on Nov 27, 2022
Haier top loader Model HWMP65-918 Machine will fill, go through all cycles, spin and drain. It wont agitate/ wash the clothes
Hi, Try a power cycle before replacing any parts. You can also turn your dial counter clockwise and retest the wash. Otherwise, I would suggest setting up an appointment with home depot to get a full list of parts that need to be replaced in your washer. Thank you.
11/10/2022 12:36:00 AM • Haier Washing... • Answered on Nov 10, 2022
My Haier portable washing machine wont do spin cycle
If resetting the washer doesn’t work, the limit switch may be stuck. The sensor for a unbalanced load is a limit switch. The switch should snap back into standby position when the wash tub comes to a stop. Sometimes the switch will stay stuck. Move the barrel by hand back and forth until it hits the inner walls of washer. It may knock the switch back in place.
12/4/2021 2:18:58 PM • Haier Washing... • Answered on Dec 04, 2021
Haier XQB60-91AF Top Load Washer Logo
9 questions posted
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Washing Machines
Most Popular Question
power cuts off
  • Washing Machines
