20 Most Recent Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB Questions & Answers
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Haier 3.6 cu.... | Answered on Jan 09, 2014
http://www.managemylife.com/mmh/owner_manuals/1018/HAIER-Chest-Freezer-L0501492
I found the manual at the above link. The Haier freezer models include:
HCM036PB
HCM045PB
HCM050PA
HCM073PA
Haier 3.6 cu.... | Answered on Jul 17, 2012
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Haier 3.6 cu.... | Answered on Jul 25, 2009
MIGHT NEED A SERVICE REPAIRMAN TO ADD FREON
Haier Freezers | Answered on Dec 20, 2019
you search on net.
Haier Freezers | Answered on Dec 13, 2019
Check it has power. Phone a repair engineer.
Haier Freezers | Answered on Nov 28, 2019
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
Haier Freezers | Answered on Oct 28, 2019
If compressor isn’t running, it’s either a thermostat / control board problem, or a power supply problem.
Haier Freezers | Answered on Jan 30, 2019
If compressor isn’t running, it’s probably a thermostat problem
Haier Freezers | Answered on Oct 11, 2018
1 = On.
0 = Off
Haier Freezers | Answered on Oct 04, 2018
Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB Logo
Popular Tags
5 questions posted
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
lost owners manual
  • Freezers
