20 Most Recent Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Questions & Answers
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Haier 20.5 cu.... | Answered on Feb 12, 2013
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Haier 20.5 cu.... | Answered on Feb 26, 2011
sound like the defrost drain line is blocked
Haier 20.5 cu.... | Answered on Feb 24, 2011
The air leaks through the door making the things melting inside. Please fix the immediately. Usually the problem is on door seal or hinges .
Haier 20.5 cu.... | Answered on Jan 10, 2011
no sounds like the door is not sealing
Haier 20.5 cu.... | Answered on Sep 14, 2010
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Haier 20.5 cu.... | Answered on Jan 20, 2009
A hum followed by a click sound is an indication of a failure at the compressor. Possibly the compressor motor has gone into a locked rotor condition. A locked rotor condition can be checked using an ammeter. The name plate on the compressor will have a rating after LRA. If the ammeter reading is equal to the LRA rating the compressor is done. If it is a reading of about 80% of the LRA (locked rotor amperage) it is possible that a relay or capacitor has failed which is replaceable.
Haier 20.5 cu.... | Answered on Sep 05, 2008
MIGHT NEED A SERVICE REPAIRMAN TO ADD FREON
Haier Freezers | Answered on Dec 20, 2019
you search on net.
Haier Freezers | Answered on Dec 13, 2019
Check it has power. Phone a repair engineer.
Haier Freezers | Answered on Nov 28, 2019
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
Haier Freezers | Answered on Oct 28, 2019
Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Logo
16 questions posted
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
just noticed about 3 days ago ice build
  • Freezers
