20 Most Recent
EA Sports Deer Hunt Challenge for Windows Questions & Answers
Deer hunt challenge wont work on windows 7
It took a lot of trial and error, but this is how I got it to work on windows 7.- Install the game- right click on the Deer Hunt Challenge SE icon- select "Properties"- click on the "Compatibility" tab, then make these changes:Under "Compatibility Mode" -- check the box that says "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop-down menu.Under "Settings" -- check the following boxes:- "Run in 256 colors"- "Disable visual themes"- "Disable desktop composition"Under "Privilege Level" :- "Run this program as administrator
How to get Deer hunt challenge to work on windows 7
It took a lot of trial and error, but this is how I got it to work on windows 7.- Install the game- Right click on the Deer Hunt Challenge SE icon- Select "Properties"- Click on the "Compatibility" tab, then make these changes:Under "Compatibility Mode" -- check the box that says "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop-down menu.Under "Settings" -- check the following boxes:- "Run in 256 colors"- "Disable visual themes"- "Disable desktop composition"Under "Privilege Level" :- "Run this program as administrator"
Game won't play on my new computer.
Are you sure the game is designed for Windows version earlier than XP? You can try compatibility mode.
- Right-click executable file of the game.
- Click Properties.
- Pick Compatibility tab.
- Check Run this program in compatibility mode for:.
- Pick version of Windows that the game was designed to work on.
- Click OK.
- Run the game.
Xbox 360 will not read my disk
do all your disks do this? if so it could be your xboxs reading lense, if not it may just be sheer coincidence the second disk didnt work, this once happened to a friend of mine, exept with gta4
I'Ve scratched my Fifa 10 disc.
EA will not replace your game disc. This happens to many gamers and it's not something they take responsibility for.
So your disc is officially garbage. But you're not completely out of luck. Do what I did. Go to
sellitbroken.com and sell your game to them. They will give you good money for it.
Will fifa 11 work on ati hd 4750??
Minimum System Requirements for Fifa 11:
Operating System : Microsoft Windows XP / Windows Vista / Windows 7
Processor : Intel Core 2 Duo at 1.8 GHz / Athlon 64 X2 Dual Core 5400+
Video Card : 256 MB VRAM - (NVIDIA GeForce 6800 or better / ATI Radeon X1600 or better) **
Memory : 1 GB RAM (2 GB required for Windows Vista / Windows 7)
Hard Disk : 6.5 GB of free Hard Drive space
Sound Card: DirectX 9.0c Compatible
Direct X : 9.0c
Controls : Keyboard & Mouse
Installation : DVD-ROM Drive
**Supported Chipsets :
NVIDIA GeForce® 6xxx series (6800 or greater)
NVIDIA GeForce® 7xxx series
NVIDIA GeForce® 8xxx series
NVIDIA GeForce® 9xxx series
NVIDIA GeForce® GTX 2xx series
ATI Radeon™ X1600 (X1600 or greater)
ATI Radeon™ X1800
ATI Radeon™ X1900
ATI Radeon™ X1950
ATI Radeon™ HD 2xxx series
ATI Radeon™ HD 3xxx series
ATI Radeon™ HD 4xxx series
Yes, it will work on an ATI HD4750.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
