20 Most Recent Nintendo DSi Black Console Questions & Answers
Two things: the dsi action replay will not stay
  1. Action Replay Not Staying Inserted:
    • The issue with the Action Replay not staying inserted into the DSi may be due to a loose or damaged cartridge slot on the DSi or an issue with the Action Replay cartridge itself.
    • Check the Action Replay cartridge for any visible damage, including bent pins or connectors. If you find any, it may need to be repaired or replaced.
    • Try inserting other game cartridges into your DSi to see if they fit securely. If other cartridges also don't stay in place, it could indicate a problem with the DSi's cartridge slot.
  2. DSi Not Recognizing Game Cartridge:
    • If your DSi doesn't recognize that there's a game in the slot, this could be related to the Action Replay cartridge, or it could be a more general issue with the DSi.
    • Test this issue with regular game cartridges that are known to work. If the DSi still doesn't recognize them, there may be a problem with the cartridge slot.
    • If other game cartridges work fine, the issue may be specific to the Action Replay. In this case, you should contact the manufacturer or distributor for support or a replacement.
In either case, if the problem persists, you may want to consider having your DSi and Action Replay inspected or repaired by a professional technician, or contact Nintendo's customer support for further assistance. Make sure to follow their guidance and ensure that your DSi and accessories are in good working condition.
11/6/2023 11:16:58 PM • Nintendo DSi... • Answered on Nov 06, 2023
Nintendo DSI screen colors inverted
GPU is on its way out main board needs replacing have a look on ebay for one
3/19/2023 11:01:43 PM • Nintendo DSi... • Answered on Mar 19, 2023
My DSi's shoulder buttons are not working
Dust and/or dirt got into the shoulder button. Just blow hard into the space between the shoulder button and where it hits the system.
Before any of the following, try either simply blowing on the button (where it meets the case) really hard (don't spit in it) or blow compressed air into it. No need to spend 60-70 bucks when youve got dirt in there. Mine stopped working last night on an airplane while my girlfriend was playing prime pinball. I did a little bit o research and found http://schlaghund.wordpress.com/2008/03/27/low-tech-ds-lite-lr-button-fix/
It worked like a charm. no need to pull it apart.
First, you will need to get a hold of a trigram screwdriver.
http://www.dealextreme.com/details.dx/sku.2905
If the button clicks but doesn't respond, likely the inside button is broken. you will probably have to get a hold of some new ones.
http://powergamingparts.com/nintendo-ds-shoulder-button-switch.html
From here you'll have to remove the old buttons and solder in the new ones.
You can also use this related link video below to as a guide.
(http://www.youtube.com/watch?v=5K3W9sbwXu8)
Hope it helps.
11/18/2021 2:35:27 AM • Nintendo DSi... • Answered on Nov 18, 2021
2answers
I accidently erased all memory
Everything is possible my friend ... ;)))
http://www.nintendodsi.com/flipnotestudio.jsp
Please rate my solution :) thanks in advance, enjoy your gaming ! :) Alex
2/25/2021 9:19:37 AM • Nintendo DSi... • Answered on Feb 25, 2021
2answers
Error code 051312-1
tengo problemas al intentar poner mi ds a internet
8/20/2019 11:55:04 PM • Nintendo DSi... • Answered on Aug 20, 2019
0answers
I need action replay dsi help!!!!
hi the files are outdated by th sounds of it.if your ds has been updated to the latest firmware it may not work either.ill give you a link R4 Card R4i SDHC 3DS Card in UK 3 99 with free shipping Recommend and Guide to Choose Best R4 Cards for 3DS DSi DS capturejuh-vyxramdeehm2ncipqdvmx3js-1-0.jpg
10/31/2017 8:27:16 AM • Nintendo DSi... • Answered on Oct 31, 2017
My dsi wont play games
It is possibly either dirty or bent contacts in the cartridge slot. If the game slides in and out easily then the pins are possibly not bent.... if it does not the pins are bent and you will need the slot replaced or replace the unit. You can use a Emery board (Yes nail file) push the board in and of of the cartridge slot. Make sure the motion is only in and out no side to side or you risk bending the pins. Hope this helps.
10/17/2017 7:06:15 PM • Nintendo DSi... • Answered on Oct 17, 2017
3answers
Have r4i gold card, dsi v1.3. have downloaded
Go to linfoxdomain, and check that you have the right software for the r4i gold, thats the only thing that can be wrong with r4i gold if you have loaded the games right, have you unzipped all the games, if you have done all that right it must be the card,
11/30/2016 3:12:03 AM • Nintendo DSi... • Answered on Nov 30, 2016
5answers
How to recover deleted photos from dsi
Here is no hope in this case. Sorry.
4/9/2016 9:01:32 AM • Nintendo DSi... • Answered on Apr 09, 2016
Bought a second hand dsi has a parental lock how
How to Change the Parental Controls:
Follow the directions below to make changes to any existing Parental Controls.
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to reach the third page, then select "Parental Controls."
  3. Select "Yes," to change the parental controls.
  4. You will be prompted for your 4-digit PIN.
    • If you know the PIN, select the empty text box and enter it using the on-screen keyboard, then select "OK" to continue.
    • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    • If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance.
  5. Select "PIN" to change the PIN or "Change Settings" to update the setting you wish to change. Once the changes are made, select "Done" to confirm any changes.
4/7/2016 6:11:38 PM • Nintendo DSi... • Answered on Apr 07, 2016
Why wont my pictures post to facebook?
1/9/2016 5:04:36 PM • Nintendo DSi... • Answered on Jan 09, 2016
ERROR CODE FOR DSI 052010-1
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings; manually assign an IP address to the Nintendo DS. Don't know how to find your router's security key? Manually assign an IP address to your Nintendo DS. For more help visit cbrtechsolutions
11/5/2015 7:20:03 PM • Nintendo DSi... • Answered on Nov 05, 2015
How do I connection settings under the enternet
What to Do:
  1. From the Nintendo DSi Menu, tap on the "System Settings" (wrench) icon. system_settings.png
  2. Tap the right arrow twice and then tap on "Internet." system_settings3.png
  5. Tap on an empty connection file.
  7. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
    • If you're unable to locate your wireless network, click here.
  8. Tap on the name of your wireless router or access point.
  9. If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point. enter_wep.png
    • If you receive the error message "That data you entered is incorrect," click here.
  10. Tap "OK," "Save Settings," and then "Yes." The Nintendo DSi will perform a connection test.
    test_success.png As long as you see "Connection test successful," the support code does not matter and can be ignored.
10/27/2015 10:18:29 AM • Nintendo DSi... • Answered on Oct 27, 2015
2answers
Forgot parental controls key
You're going to have to call nintendo to remove the parental controls. They will give you a special code to remove the parental controls.
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
    • If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
  5. Select "Clear Settings," then select "Yes" to confirm.
9/20/2015 2:23:33 PM • Nintendo DSi... • Answered on Sep 20, 2015
Nintendo DSi Black Console Logo
1,201 questions posted
Popular Products
Nintendo Wii Console
11,924 Questions
Nintendo DS Console
Nintendo DS Console
1,598 Questions
Nintendo 64 Console
Nintendo 64 Console
763 Questions
Nintendo DS Lite
Nintendo DS Lite
788 Questions
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
0000fefe error code got happened
  • Video Game Consoles & Games
