20 Most Recent
Sony Ericsson TM506 Cell Phone Questions & Answers
The battery discharge so fast even with a new
Your phone battery terminals are corrode that is why it discharges all your phone batteries so fast.
All you need to do is to replace the battery terminal of your phone and you will see that your battery will last you very long.
Take care.
The message memory is clear bt i can't reply massage
Check all your drafts and saved messages. If any clear them. Also clean your outbox or sent items. Change settings from sim storage to phone storage. You can do this by going to message settings > memory in use> and so on.. again depending on your phone.
Free unlock code
Hi, If you are searching for a Network unlock solution for your Sony Ericsson T506,Then I would suggest you to use the paid unlock code to unlock It ,because free unlock code are less reliable and not a permanent unlock solution for your mobile.If you are interested then you can get the unlock code at low cost from the site
TheUnlockSpot.com by providing some basic information about the phone like the country and the network to which the phone is locked to.After providing this information you will get the unlock code via mail,using the unlock code you can unlock your phone safely to use it with any other GSM network of your choice.
Unlock network lock
You can remove network lock on your Sony Ericsson TM506 mobile phone
using network unlock code.It's one of the best way to unlock your
mobile phone.If you need an unlock code visit
Prounlocking.com Here you can unlock your mobile phone at low cost.
Unlock network lock iran
You can remove network lock on your Sony Ericsson TM506 mobile phone using network unlock code.It's one of the best way to unlock your mobile phone.If you need an unlock code visit
Unlock code sony ericsson tm506
Hi, You can get the unlock code for a Sony Ericsson TM506 from
www.unlocking4u.com/sony-ericsson-tm506/rs6wp9/ at affordable cost. Here are the steps for unlocking a Sony Ericsson TM506,1 - Switch ON your Sony Ericsson TM506
without any SIM Card,
2 - Press the
left arrow key/button
once,
3 - Press the
button * twice,
4 - Press the
once,
5 - The message "Personalize with MNC2" will appear, (or you will have
displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
I can't pair Technocel T10 bluetooth with motorola
With T10 off, hold the on/off button down. In 4 seconds the blue light will begin to flash but continue to hold down on the button until the red light also appears. You can now pair the T10 with the phone.
Freezing and shutting off
Hello,the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.To solve the problem, you need to flash the phone . Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.You can use software updater to flash the phone. Download software updater from sonyerricon.com. Install it on your computer, open the software updater, connect the phone via usb cable to your computer. Allow the computer to recognize the phone, then click update. Follow all direction from the software updater application. And your computer must be connected to the internet.I hope you understand this.Good luck.
Unlock code
Yes..There is a code to unlock your Sony Ericsson.I found an unlocking service for your mobile at
Mobile-unlocker.com .Through this you can unlock your mobile easily..
The external display screen for my sony ericsson
unlocking a phone can be done by many ways but the best method and the
safe way to unlock a phone is through codes. even in codes too there
are many providers who offer you free services. but free codes are
risky. they may go wrong while generating codes and when the number of
attempts exceeds it may lead to hard reset your phone which is a double
work for you. so its better to get codes from paid services to unlock
your phone. i got my phone unlocked through one such paid services. here
is it.
TheUnlockspot.com you can even try them.
