20 Most Recent
UTStarcom Blitz Cell Phone Questions & Answers
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this
option, you must install V CAST Music with Rhapsody on your PC.
1. Open V CAST Music with Rhapsody software. Don’t have V CAST
MUSIC with Rhapsody software? Download it for free at
www.verizonwireless.com/music.
2. Install the device USB drivers before connecting your phone to
a PC.
USB Cable and Device Drivers can be purchased separately via the Music Essentials
Kit compatible with this device.
3. From the main screen on your phone, the SYNC MUSIC V CAST
MOBILE PHONE display appears. Your phone should display the
message: Connected.
Connection may take a few seconds.
4. Drag and drop the song(s) you want to sync from My Library, to
your V CAST Music with Rhapsody mobile phone, listed under
the Sources tab. Once synchronization is complete, press the
END/Power Key and disconnect the USB cable (purchased
separately).
5. Under the Music & Tones menu, open My Music to view and play
your music.
• A compatible USB cable (sold separately) is required for syncing.
• Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Pantech service code
Hi if you are looking for code to unlock your pantech phone from its present network ..Then have a look at sites like
Mobile-Unlocker.com here they are rendering unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your mobile model, country and network.if yes then pay for it and unlock your phone ...
Keeps resetting
ha ha ha as you like i think you need to check battery first, if it shows in the screen that the battery still charging all they long but actually a faulty battery doesn't charge..
Fix screen
screen still black / white it's not a screen problam .it's belt problam change your belt of cell who connect your slider to your keypadthat belt.
Also along with not being able to hear the call
Reset the phone back to factory default as i will advice, this should fix all the problem with the phone, follow the steps below to reset your phone.
go in to tools/phone settings/security/reset phone. Security code is six
zeros and the passcode to reset is the last 4 of your programmed phone
number. this should fix the problem.
Take care.
My screen is broken and only my keyboard is
lol i did the same thing, and mine didnt work anymore so i just broke the p.o.s.. i opened it up and theres something that has to hit a certain post and you may have knocked that off place and or there is also a ribbon wire that may have become destroyed or damaged from a partial cut and or rip. sorry buddy. ure sol
My blitz wont charge
Hello
What you need to do first is to open the back of your phone,remove the battery and check if it is swollen,if it is then it is damaged but if its not then place the metal-like charging port on the battery to your tongue and see if it shocks a little then the battery is ok but if no it is no longer strong,After that you would check the pins inside the phone that contacts the battery if no one is damaged,then check if there is a contact between the battery and the pin.
After all the procedure and the phone doesn't charge then you would have to replace the charging port of your phone in order for your phone to work perfectly again.
TAKE CARE
Pantech blitz txt 8010 cell phone locked and I
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
