10 times flashing of the led light indicated of "HV protection" circuit was activated to avoid further damaged to other components.
Affected parts are as follows.
> Shorted Q8014 or Q8013 in the D-board.
> Open R8051 in the D-board also.
Q8014 and Q8013 are both
2SK2842 which cost $6.14 each.
R8051 is a f
usible resistor 0.1 Ohms,1/2watt which is cost $2.95 each.
If your handy with electronics, you may replaced the parts yourself. However if you can't troubleshoot the unit yourself, I would advice you to look for an experienced technician to replace the parts for you. Service fee range about $200-$300 depends upon the skills of the technician.
To save some money, you may look for a friend with some basics knowledge in electronics. Since the part to be replaced was already pinpoint this is not quite technical.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
