20 Most Recent Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera Questions & Answers
There're actually two buttons. Press and hold the Info and zoom-in buttons (both marked with a green dot) for more than two seconds.
Full details are in the "Two-Button Reset" section of the manual (page 38 in my copy). If you need a manual you may download a copy from here.
Nikon D60 + AF-S... | Answered on Jan 08, 2013
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Nikon D60 + AF-S... | Answered on Jan 18, 2011
You can reset the camera by using a paperclip and pressing the reset button
Nikon D60 + AF-S... | Answered on Dec 31, 2010
Is the camera in airplane or power saving mode?
Nikon D Cameras | Answered on Feb 02, 2019
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
Nikon D Cameras | Answered on Aug 02, 2018
switch button got damage due to hard press so you need to replace it
Nikon D Cameras | Answered on Aug 24, 2017
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Nikon D Cameras | Answered on Dec 11, 2016
Have you tried to see if you camera is running the latest firmware? If its not update it.
Nikon D Cameras | Answered on Jul 02, 2016
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600.
Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
Nikon D Cameras | Answered on Jun 08, 2016
Format the SD card first.
Nikon D Cameras | Answered on Apr 17, 2016
Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera Logo
4 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
reset switch nikon d40 camera reset
  • Cameras
