20 Most Recent Samsung S85 Digital Camera Questions & Answers
Lost software cd for samsung camera s85
Go to their download center.
http://www.samsung.com/us/support/download/supportDownMain.do
enter model number and follow directions.
Happy downloading!
6/18/2019 4:47:03 AM • Samsung S85... • Answered on Jun 18, 2019
2answers
Samsung S85 camera wont turn on. When the power
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
11/19/2014 6:38:14 PM • Samsung S85... • Answered on Nov 19, 2014
0answers
0answers
0answers
Lost CD for samsung st200f
You don't need any special software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
3/7/2013 4:11:16 PM • Samsung S85... • Answered on Mar 07, 2013
How do I turn off the flash on my s85?
Press cursor-left (marked with a lightning bolt) to bring up the flash menu, then select the lightning bolt in a circle with a slash through it. Full details are in the "Flash/Left button" section of the manual (beginning on page 26 in my copy). If you need a manual you may download a copy here.
1/8/2013 7:52:11 PM • Samsung S85... • Answered on Jan 08, 2013
Lens opens,closes, beeps 3times, turns off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/27/2012 4:20:58 PM • Samsung S85... • Answered on Dec 27, 2012
I need to find a way I can download the software for my SamsungS85 camera
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
10/8/2012 2:46:41 AM • Samsung S85... • Answered on Oct 08, 2012
Camera lanse did not come out and camera didnot come on ?
Try the procedures in this tip.
9/22/2012 11:42:04 AM • Samsung S85... • Answered on Sep 22, 2012
Samsung S85 lens cover only closes halfway
Sounds like the lens cover will have got knocked off the guide rails, not much you can do, try blowing it with some compressed air incase there is any debris/grit stuck in there
6/22/2012 9:48:17 AM • Samsung S85... • Answered on Jun 22, 2012
Clusters of dots appeared on the screen, how can I
If they don't appear on the actual pictures, they are probably dead pixels and there's not much you can do about them.
10/5/2011 9:27:31 PM • Samsung S85... • Answered on Oct 05, 2011
I am trying to move
Go into the menu and find "copy"...it should give you that option.
8/5/2011 8:27:22 PM • Samsung S85... • Answered on Aug 05, 2011
0answers
Software wont install on my computer for samsung
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery or Picasa ( http://picasa.google.com ).
6/30/2011 7:20:49 PM • Samsung S85... • Answered on Jun 30, 2011
I have a samsung Digimax
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
6/27/2011 8:01:12 PM • Samsung S85... • Answered on Jun 27, 2011
How do you load the
The camera should have came with a software CD. Install the software and drivers from the CD and plug your camera into the computer with the supplied cable and the computer will read your camera as a drive. Then you can just drag and drop the pictures from the camera folder to your computer.
Or you can buy a cheap USB card reader that will read either MMC or SD card depending on what you're using. Then you don't need to plug in camera to computer. You would need to remove the memory card and plug it into the USB card reader.
5/13/2011 6:29:52 PM • Samsung S85... • Answered on May 13, 2011
4answers
I have a cracked lcd. I have the replacement
The lcd screen is held in place by a metal bracket, which usually has 2 or 3 screws to secure it to the main circuit board. Remove these with a jeweler's screwdriver, and gently lift the lcd and the bracket up out of the holder. The next step is to disconnect the ribbon connector by gently liting the plastic connector bar holder up, releasing the ribbon. There is always one wide connector, and sometimes a narrow one for the backlight. Installation is the reverse. You can install the battery at this point and check to make sure the screen is functioning. There are some videos about this procedure on YouTube, and if you search for "Samsung S85 lcd screen replacement" you may find one specific to your camera, but you can do a more general search for "lcd screen replacement", and find some videos that might help you see the process.
You're almost there...just carefully look for the holding screws on the metal holding bracket.
Here is a link to a procedure for one of the more difficult ribbon connectors, on a Canon Powershot, but the process is similar, and hopefully will give you the information to complete this task. http://cannonlcdrepair.blogspot.com/
Good luck, and hope this helps!
4/28/2011 11:35:24 AM • Samsung S85... • Answered on Apr 28, 2011
Will not download photos
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/2/2011 6:21:44 AM • Samsung S85... • Answered on Apr 02, 2011
Samsung S85 Digital Camera Logo
49 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
lost cd samsung st200f
  • Cameras
