20 Most Recent Acer Aspire One Netbook 8.9" Notebook Questions & Answers
5answers
Transfer internal to external monitor port
use your fn key together with f4 from your keyboard. it will display to your monitor.
12/25/2023 10:31:38 PM • Acer Aspire One... • Answered on Dec 25, 2023
Acer aspire one aoa150-1283 up grade Win XP to windows 7
Win 7 will use more resources and make it slower. It is a nice netbook, but still a netbook. Plus you need to consider drivers for, LAN, sound, and video. Try testing with Win 7 advisor,http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
5/4/2023 9:19:15 PM • Acer Aspire One... • Answered on May 04, 2023
Acer aspire one zg5 netbook wont update windows
You can try updatinv windows manually by choosing the option which says let me choose the updatestry installing .net frame work serial wise like first install 2.0then 3.0 then 3.5 and at last 4.0 just write in google microsoft .net frame work and it will give you the dowload links...check your system for viruses as well with tools like hitman pro and malware bytes
8/6/2022 11:32:44 AM • Acer Aspire One... • Answered on Aug 06, 2022
Acer aspire one crashed and is stuck in an endless boot cycle because an 'autochk' file is missing, so sayeth the blue screen of death......
no pc model told at all just inches. no OS told last guy on XP on earth?the virus magnet from H3LL. well if the hdd is bad, all that you told is what happens. no hdd this old works why mess with any old hdd, get a SSD in there and learn to backup private data. or lose it you will so what now? and answered here 1000 times move then hdd to 2nd GOOD pc with spare SATA port and get your data that way, if possible at all?"and only trying wins.. or to USB sata docking bay a $15 tool) the old OS image files for recoveyr die the day any hdd dies. this is REALTY . best is learn to backup,
5/27/2022 5:23:47 PM • Acer Aspire One... • Answered on May 27, 2022
2answers
I have the Netbook and just bought an external DVD
Control Panel -> System -> Hardware tab -> Device Manager
Click [+] next to DVD/CD-ROM drives, double-click the drive in question.
In Properties tab, make sure the box is ticked next to
Enable Digital CD-Audio for this Device
Hopefully you'll have sound after this.
3/24/2020 7:22:45 AM • Acer Aspire One... • Answered on Mar 24, 2020
2answers
Why is it lagging?
use any othere webcam software.. and use VLC player for playing videos...
3/11/2020 7:30:19 AM • Acer Aspire One... • Answered on Mar 11, 2020
Emachines netbook wireless connection not working
Have you checked the encription method (WPA or WEP) - usernama and password or just a password for the second type
8/28/2018 12:02:56 PM • Acer Aspire One... • Answered on Aug 28, 2018
Insuffient system resources exist to complete the
Your problem can be cured by simply increasing your paging file size or adding more Ram. Here is an explanation of what an API is and does.
An application programming interface (API) is an interface implemented by a software program to enable interaction with other software, similar to the way a user interface facilitates interaction between humans and computers. APIs are implemented by applications, libraries andoperating systems to determine the vocabulary and calling conventions the programmer should employ to use their services. It may include specifications for routines, data structures, object classes and protocols used to communicate between the consumer and implementer of the AP
6/12/2018 12:16:08 PM • Acer Aspire One... • Answered on Jun 12, 2018
3answers
Iam on my daughters laptop
  1. Click on Start and then Control Panel.
  2. Click on the User Accounts and Family Safety link.
  3. Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link. Simply click on the User Accounts icon and proceed to Step 4.
  4. Click on the User Accounts link.
  5. In the Make changes to your user account area of the User Accounts window, click theChange your password link.
  6. In the first text box, enter your current password.
  7. In the next two text boxes, enter the password you would like to start using.
  8. Entering the password twice helps to make sure that you typed your new password correctly.
  9. In the final text box, you're asked to Type a password hint.
  10. This step is optional but I highly recommend that you use it. If you try logging in to Windows 7 but enter the wrong password, this hint will display, hopefully jogging your memory.
  11. Click on the Change password button to confirm your changes.
  12. You can now close the User Accounts window.
  13. Now that your Windows 7 password has been changed, you must use your new password to log on to Windows 7 from this point forward.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
3/18/2018 11:18:04 AM • Acer Aspire One... • Answered on Mar 18, 2018
Acer aspire one d257 - 13404 where is the
It means that either your boot files or your operating system is corrupt. You need a system repair disc or a operating system disk to fix the problem. One other problem could be that your hard drive has crashed and you lost everything, but I don't think that's your issue.
3/9/2018 11:24:05 PM • Acer Aspire One... • Answered on Mar 09, 2018
Erecovery management for acer aspire one without disk drive wont run
Ask acer for this problem, when you buy a laptop you need to make recovery discs, you prolly did not do that. So now it asks for recovery files on the dvd disc. If it has no dvd drive you should have made them on a usb drive. If acer cant help you with that, reinstall windows thats the only option. Partitions hidden can be removed but then there is no way to restore the pc to factorydefaults anymore. When you decide to reinstall windows, you will see 3 partitions, remove them all, then make 1 partition click next and it will make a little partition for system files. the rest is used for windows, untill u partition the rest, like a d: e: drive.
2/13/2018 11:15:29 AM • Acer Aspire One... • Answered on Feb 13, 2018
Please input password for WDC WD1600BEVT-22A23.
only you would know the answer to this question.
2/5/2018 1:27:11 PM • Acer Aspire One... • Answered on Feb 05, 2018
I have an Acer Aspire
when you reboot the computer to start in safe mode by pressing F8 key and then try to change the resolution of the monitor.
12/29/2017 1:16:08 PM • Acer Aspire One... • Answered on Dec 29, 2017
Hi, I plugged in my
Hi, Try this Unplug the power cord from wall and from computer completely Remove the battery from laptop Wait about 1 min. Then replace the battery then the power cord Turn laptop on
11/8/2017 12:12:42 AM • Acer Aspire One... • Answered on Nov 08, 2017
Hi there, am having problems with my daughters
Hi, Try rebooting using the original the original Windows that came with your computer
11/8/2017 12:00:11 AM • Acer Aspire One... • Answered on Nov 08, 2017
My Acer netbook 8.9" is
in windows 7 F8 is the key of enable safemode
10/7/2017 7:34:45 PM • Acer Aspire One... • Answered on Oct 07, 2017
0answers
2answers
Hi! i have a acer aspire one, everytime i switch
Privacy Center, or PrivacyCenter, is a rogue anti-spyware program designed to trick users into purchasing its full rogue version. Privacy Center looks similar to Privacy Components. Privacy Center may infect your computer through a Trojan, spam emails or it may have come bundled with another malicious program. Privacy Center sells itself as an effective spyware remover tool, however, all it does is make you believe you're infected with numerous spyware threats to offer its "licensed" program.
Go to the link below and download and run MalwareBytes Anti-Malware program. When it installs it will ask to update and run, please do both. Once it updates, run the program and perfrom a QUICK scan only. When it is through scanning it will ask you to click on the show results button. When you do that it will show you the infections it has found, make sure they are all selected and delete them. You should be malware free now.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
12/27/2016 8:12:05 PM • Acer Aspire One... • Answered on Dec 27, 2016
3answers
It plays through built in speaker even when
Try a different set of headphones, it sounds like the computer is not recognizing that the headphones are plugged in. Does the computer put sound out through the headphones as well?
12/14/2016 7:37:17 AM • Acer Aspire One... • Answered on Dec 14, 2016
How do i use my whatsapp on my laptop
Whatsapp currently does not support tablets, computers, or Wi-Fi only devices.
10/27/2016 7:04:12 AM • Acer Aspire One... • Answered on Oct 27, 2016
Acer Aspire One Netbook 8.9" Notebook Logo
2,451 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
insuffient system resources exist
  • Computers & Internet
