20 Most Recent HP Pavilion dv9925nr Notebook Questions & Answers
NO OS stated, how can any one help lacking what windows this is
XP, W7,8/10" what?
sound dead, on internal speakers, that it?
first remove all usb devices, for sure USB HEAD PHONES!
the HP software is missing,, someone deleted that.
I bet its a pure software problem
and wrong drivers loaded. ever try HP drivers from REAL HP.com>?
this PC is as old as 2007 , 10 years old.
get the driver now, and not miss out when HP deletes them.
here is your driver page, seems it's visa new.
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9900-entertainment-notebook-pc-series/3725216/model/3740566
HP Pavilion... | Answered on Oct 08, 2017
If it doesnt start,make sure you hear the power supply turn on.if no noise at reboot,replace the powe supply
HP Pavilion... | Answered on Apr 12, 2017
You can find the bios flash the manufacturers site. But your system might already have the latest bios so be careful. You screw up the bios and you're toast.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Bios drivers. You will have to flash the bios. Look on the site for manuals to search for flashing the bios.
Also look at the bios version that is on the website to download, you might already be at that version.
HP Pavilion... | Answered on Jan 11, 2016
Very simple, first take backup of all your Data on a Separate Hard Drive or CD, DVD, BluRay or Pen Drive etc. Afterwards, use your Operating System disk (that you're going to use after formatting), as you insert Operating System CD/DVD in your CD/DVD Drive, you'll get options out of which one would be suggesting you to format your Hard Disk, In Format Options, you'll get two sub options or even more, better and safe to choose default option (On which the cursor automatically sets before you choose, but if uncomfortable, call your Computer Service Center). As you hit that option, you'll find your Hard Drive getting formatted and after that, your computer will prompt you with Operating System Installation options.
And if you're about to format a Hard Drive, but not to setup an Operating System on it, even easier: After Backup of your data on that Hard Drive, just right click its icon and choose Format and you'll be able to do so after a few options.
Also, you can learn from Help and Support Section.
HP Pavilion... | Answered on Jan 18, 2015
Have it checked in service for video chipset problems please
HP Pavilion... | Answered on Apr 17, 2013
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
HP Pavilion... | Answered on Feb 21, 2013
go to start menu type in search bar adjust screen resolution then click on advanced settings should find what u need there
HP Pavilion... | Answered on Jan 05, 2013
Try these steps first.
  1. HP players usaully pop out. There should be a release underneath the unit (may have a screw). Re-seat the player, and check.
  2. Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
  3. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
  4. Check part number and order a replacement.
HP Pavilion... | Answered on Oct 01, 2012
Hi fgleaves...
Try hooking your computer to an external monitor...if you get a picture then more than likley your lcd screen needs replacing...if no picture then its maybe your lcd inverboard needs replacement.
Please take time to rate me
HP Pavilion... | Answered on Sep 23, 2011
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
HP Pavilion... | Answered on Sep 22, 2011
Pretty much your tech is spot on. The system is not posting. You can remove all drives and RAM and see if the symptoms change, if not then the motherboard is the failure point. Replacement MB I found was $383 including shipping
http://cgi.ebay.com/HP-Pavilion-dv9000-dv9925nr-AMD-MOTHERBOARD-459567-001-/360337113764?pt=LH_DefaultDomain_0&hash=item53e5c402a4#ht_3860wt_905
HP Pavilion... | Answered on Jan 25, 2011
Take out the keyboard and see any liquid got into the motherboard. Thake out the keyboard screw at the botton. You can get the service manual from hp.com if needed.
HP Pavilion... | Answered on May 21, 2010
It is glossy type, that is not good to view outdoor. I believe it has only one backlight bulb.
CompQ
HP Pavilion... | Answered on May 10, 2010
have u tried searchin for other softwares other then yahoo messenger try skype
HP Pavilion... | Answered on Mar 31, 2010
A DVD player that is an integral part of the laptop does not need drivers to make it play discs. If there is no driver shown, maybe the DVD unit is faulty?
All laptops will play CD/DVD from boot without drivers. The drivers are there to allow you to do specifics to the DVDs.
HP Pavilion... | Answered Yesterday
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
HP Pavilion... | Answered on Jul 31, 2019
you can try going into your control panel and look for the speaker icon click in there and you should be able to set your sound settings.
HP Pavilion... | Answered on Jul 15, 2019
HP Pavilion dv9925nr Notebook Logo
27 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
reformat pc hard drive
  • Computers & Internet
