20 Most Recent
AMD IC Power CN5560 Notebook Questions & Answers
Ic problem
if the ic problem. remove it and change it.. use hot air to remove the ic's
Lost my wifi and sound
reinstall the device drivers. right click on My computer then select manage. Under device manager, you'll see the devices that have an exclamation point. Remove and reinstall.
The power outlet on my IC Power laptop is not
so its most likely a problem with just the jax on the laptops end, you would have to take the unit apart entirely and re-solder the connector or replace it to a new one, you can find a replacement from ebay.
if you could post me the brand and model I'll take a look.
I may have a virus. Operating program won't open.
try restarting the PC in Safe Mode. Upon reboot keep pressing the F8 key. It will open a selection menu for you to choose safe mode. Go into Safe Mode and open your My Computer and right click on the C drive and go down to properties. THen go to the Tool tab and select the Check Disk option. It will ask you to check two boxes and then it will say you need to reboot your PC. Reboot your PC and let it run. Once its done it will automatically start back up with the OS. If your still having issues then restart the pc and go back into safe mode and this time run your anti virus program.
Hope this helps...
Need drivers for my DVD/CD RW
optical drives are like hard drives which work as plug and plays. They are automatically detected by the operating system. What is provided for optical drives are usually firmware updates if needed. You can check out the web site of your notebook manufacturer as they usually post drivers and firmware updates for your system, or search the model of your drive through its specific manufacturer to look for firmware updates.
