20 Most Recent Goodman CKL24AR24 Air Conditioner Questions & Answers
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Goodman... | Answered on Nov 15, 2015
fan relay stuck in or thermostat set to fan on.
Goodman... | Answered on Aug 14, 2015
compressor not running or low freon. try replaceing compressor capacitor.
must be a heat pump control issue.
Goodman... | Answered on Aug 12, 2015
bad motor or blade.
either a safety taking it out or loose wire problem.
Goodman... | Answered on Aug 11, 2015
check breaker and make sure you have 24 volts at contactor. if all ok replace contactor.
Goodman... | Answered on Aug 09, 2015
it is a question of efficiency. they try to keep air moving across a cold coil.i dont like it in our humidity in houston it results in the air picking up moisture and adding it back to room.
Goodman... | Answered on Jul 04, 2015
You can try recharging, the refrigerant system has an electric switch for low pressure cut off that won't let the compressor turn on when there is not enough gas pressure. There is also a coolant temperature electric thermo switch that cuts off the compressor when the coolant or engine has overheated. If it's not low on refrigerant gas, then an electric problem needs to be diagnosed. A service or repair manual would then come in handy.
Goodman... | Answered on May 05, 2015
I would think the condensor motor bearings are worn. Try testing for end play and side to side play of the condensor motor shaft, with the power disconnected.
If you have a split unit, it is fairly simple, just feel the small refrigerant line coming out of the unit. The temperature should be warmer than the surrounding air. If is not running the temperature will be the same as the surrounding air. If you have a package unit, take off the access cover to where the compressor is located. Find the compressor discharge piping to the the condensing coil. It is the smaller of the two major pipes on the side of the compressor. Be careful the temperature of line coming out of a properly operating compressor will be hot enough to cause second degree burns. If the line is very warm to very hot the compressor is running. If you have a set of gauges, attach the RED hose to the high pressure service connection and the other low pressure hose BLUE to the bigger pipe low pressure connection. Make sure the gauges are isolated by shutting the valves. The pressure difference between high and low pressure is normally at least 150 psig diference.
Goodman... | Answered on Oct 14, 2014
I believe that the higher end units have auto reset pressure switches, if you look down the inside of the unit, you will see one or two pressure switches welded to the lines,,,there are about the size of a "C" cell sized battery, with 2 wires running into them, if it is a manual reset type there will be a small rubber coated button on top, between the 2 wires.
If this has been helpful, please rate me, and/or contact me back with any further questions.
Sincerely,
Paul Gibson
Goodman... | Answered on Sep 23, 2014
Line set could have rubbed a hole n it
Goodman... | Answered on Jul 26, 2014
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
Goodman... | Answered on Jul 01, 2014
Typically the outdoor fan motor does not need to be oiled because it is sealed and permanently lubricated.
Goodman... | Answered on May 17, 2014
the condenser is the outdoor coil which rejects or absorbs heat to the atmosphere
Goodman... | Answered on May 16, 2014
no you cannot put a 2 1/2 ton compressor into a 2 ton condensor. you could put a smaller compressor into a condenser and you will gain effeciency put loose capacity
turn off power remove blower housing (screws and wires) use a crescsent wrench to loosen bolt and reset wheel on shaft in the center of housing and then retighten bolt be sure to set it on the flat part of the shaft then reinstall in reverse order
capacitor? will hum if contactor pulled in but no ac power. will hum if contactor pulled in and bad capacitor. depends on how lowd the hum is. loud hum prolly equals bad capacitor
Goodman CKL24AR24 Air Conditioner Logo
154 questions posted
Top Goodman Heating & Cooling Experts
Paul Carew
Brad Scarpetta
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goodman Heating & Cooling
Most Popular Question
compressor fan motor runs backwards
  • Heating & Cooling
