20 Most Recent eMachines ET1161-03 PC Desktop Questions & Answers
Emachine ET1161-03 would not turn on anymore after
the hard drive needs to be replaced
6/26/2017 1:14:30 AM • eMachines... • Answered on Jun 26, 2017
Each time I shut down my ET1161-03 emachine, it does not retain the boot menu defaults. How can this be fixed
Create a new user profile and start using that one after you copy your stuff from the old one.
8/18/2014 4:27:22 PM • eMachines... • Answered on Aug 18, 2014
Need to plug case cables back in on the motherboard
ANSWERD.
12/4/2013 9:48:24 PM • eMachines... • Answered on Dec 04, 2013
Plug in case cables to motherboard
12/4/2013 9:38:34 PM • eMachines... • Answered on Dec 04, 2013
Emachine fans
upon turning on keep hitting f8 repeatedly to get to the bios menu and check your boot sequence
9/15/2013 4:59:25 AM • eMachines... • Answered on Sep 15, 2013
Won't connect to router
Shut down compter, unplug router and the ISP modem, Check ALL cables and reseat ALL connections, plug in the ISP modem allow it to selftest, plug in the router allow it to selftest. Reboot the computer, plug in Ethernet cable.You didn't give much info to work with. Wired? Wireless? Does it connect to other devices? What is the OS? Vista? Is this a recent issue? What it the router Make ,Model? Open the Network and Sharing Center, Manage Network Connections, Is the Ethernet Adapter enabled?
1/7/2013 11:44:11 PM • eMachines... • Answered on Jan 07, 2013
Need to attacth led and sw cords in motherboard
Can you be a bit more clear? "led and sw cords" ?
12/8/2012 12:48:31 AM • eMachines... • Answered on Dec 08, 2012
On board sound card driver for emachine ET1831-03
Which operating system ?
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free also http://download.cnet.com/2000-20_4.html
Just type in what you want or need be specific you might have to try a few times to get it right.
Tick in either the all software or the windows software box.
IE: motherboard name sound drivers
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Hope it helps.
11/28/2012 1:42:41 PM • eMachines... • Answered on Nov 28, 2012
Using a tv as a monitor
You will need to connect to another monitor or your television to your computer with the vga lead monitor connection.
Click start control panel display change display settings adjust resolution this may vary depending on your operating system
You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changesHope this helps
11/22/2012 11:41:09 PM • eMachines... • Answered on Nov 22, 2012
I need the following xp compatible drivers for the
Try this link.
http://support.gateway.com/support/drivers/ddaStep.asp?Tab=All
All the driver you need should be here.
Let me know
9/4/2012 6:49:21 PM • eMachines... • Answered on Sep 04, 2012
My computer has a virus and I want to get rid of it
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
6/25/2012 10:56:41 AM • eMachines... • Answered on Jun 25, 2012
Need tech manual for
There's not much to it. The cables from the power supply will only go in certain slots on the motherboard.
6/2/2012 2:52:59 PM • eMachines... • Answered on Jun 02, 2012
2answers
How do reset my emachine et1161-03 to factory settings
you press bio key f1 f2 and bio mother board deafult bio and slove the problem
3/6/2012 3:39:44 AM • eMachines... • Answered on Mar 06, 2012
How do I do a
most pc maker has an aditional partition called recovery...you can use it since the bios boot
press f1 for bios setup
pres f10 for recovery
press f12 for boot order all you need to do is select recovery
5/18/2011 5:09:53 AM • eMachines... • Answered on May 18, 2011
I can see the dvd/cd drive but it will not play
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
11/29/2010 12:44:21 AM • eMachines... • Answered on Nov 29, 2010
I am looking for scsi
If your system is still running the same hardware as when you bought it, you should be able to download the drivers at the eMachines support website at.
http://www.emachines.com/support/drivers.html
In the menu, click the following options
1. Desktop
2. ET Series
3. ET1161
Unfortunately they only have vista drivers available. eMachines tends not to smile on users using anything but the given OS, so you are out of luck if you want XP drivers for the system.
10/22/2010 3:11:51 AM • eMachines... • Answered on Oct 22, 2010
eMachines ET1161-03 PC Desktop Logo
40 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
pc shuts down hard start usually takes 4
  • Computers & Internet
