20 Most Recent Goodman CLQ36AR49 Air Conditioner Questions & Answers
I never heard of something like that before.
Goodman... | Answered on Jan 06, 2018
Hi! AC Unit
Sorry you have had so much trouble. Sounds like with the factory warranty being in effect the whole outside condensing unit should be replaced. With this type of problem there could be some blockage in the AC lines. With out some pressure reading it is hard to tell if the expansion tube is plugged, or there is some other major problem. If your service tech is unable to diagnose the problem you may need to get a third opinion. Goodman may have a factory representative in your area. You may be able to find some help with a different dealer or online. Good Luck! I will try and look for any changes.
InMrFxIt
Goodman... | Answered on Nov 23, 2017
control board low voltage problem
Goodman... | Answered on Jan 28, 2017
Try replacing the batteries first. The blinking may be the battery indicator.
The fact that it blows air when you turn the thermostat to cool tells me that the thermostat is probably working. The problem is most likely outside at the condensing unit. There are lots of potential problems that could be found out there. Sounds like you will need a technician.
Goodman... | Answered on May 26, 2016
Sure can be replaced,Chinese ppl, copied everything,u can find local dealer for selling remote controller, or u might buy a multi one can be used for several devices by preserved codes to be entered in the remote to send to any device
Goodman... | Answered on Aug 24, 2015
if your calling for cool replace contactor.
Goodman... | Answered on Aug 18, 2015
Consider the power consumption and Voltage of Air conditioner . Why you might ask because you can calculate likely current requirement. Power = Voltage x Current. So Current = Power / Voltage. Eg a 4800 Watt power on say a 240 Volt supply. Current calculation 4800/240 = 20 amps. As a rough guide what fuse rating is the fuse in the fuse box of the house for the AC power point. I would think 15 amp for lighting and between 20 Amp to 30 A for power.
see http://www.simplifydiy.com/electrical/basic-electrics/fuses
Goodman... | Answered on Aug 15, 2015
match the one thats there..
Goodman... | Answered on Aug 14, 2015
bad capacitors, contactor, fan motor, or compressor.
3 ton
you can't. replace motor.
Goodman... | Answered on Aug 12, 2015
if you can turn blade by hand freely try capacitor.
always in return through a grill
check capacitors get someone to take amp reading while running.
the outside of a window unit is like a vacumn cleaner running depositing any dirt in air on coil surface. you can clean coil sounds like it's needed.
sequencer not working to provide power to strip.
high side pressure equalizing across orfice. typically you can't hear it.
24 volts is what you would expect on secondary
Goodman... | Answered on Aug 11, 2015
Goodman CLQ36AR49 Air Conditioner Logo
444 questions posted
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Brad Scarpetta
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goodman Heating & Cooling
Most Popular Question
goodman air conditioner model ck49 1b
  • Heating & Cooling
