hshorty,
When you press the plastic Power On button, it in turn presses
against a Power On switch.
The Power On switch is located inside the
plastic Power On button.
This is an example of a generic ATX Power On
switch,
http://www.directron.com/atxswitch.htmlThe switch completes a
circuit.
(The Power On switch is a Momentary Contact Switch. Makes a
brief contact, then opens back up)
The circuit the Power On switch
completes, is the 5 Volt Standby circuit.
When a Power Supply is plugged
into power, there is a constant 5 Volts (DC) present.
Closing this 5
Volt Standby circuit, momentarily 'excites' the Power Supply, and turns
the Power Supply on.
Power goes to the Motherboard, and Peripherals,
(Harddrive, optical drive/s, and so on)
The first chip to receive power
is the BIOS chip.
(Chip and Chipset are slang terms for I.C. Integrated
Circuit)
The BIOS program on the BIOS chip, looks to see what devices
are installed, does a Ram Memory count, TURNS the Processor on, and
hands the computer over to the O/S.
(O/S = Operating System. Windows XP
is one example of an O/S)
Your Power Supply doesn't even have enough
power to light those LED lights, much less turn the Processor on.
A)
ALL the LED lights together, use less than 1 Watt of power.
B) EACH fan
uses 2 to 3 Watts.
C) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is. (Older Processors use less than 51
Watts)
If this problem is in reference to a Compaq Presario SR5130NX
desktop computer, it comes with an Athlon 64 X2 - 3800+ Processor.
(Windsor Core. Also this Processor uses an AM2 processor socket)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01048297&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3436820This Processor can use up to 89 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Windsor.22_.28F2_.26_F3.2C_90_nm.29 Fans start to spin, and the LED power light is on for the Power Supply.
When it's time to turn the Processor on, too much power is needed, and
the Power Supply 'drops to it's knees'.
The Power Supply used is just a
common ATX style of power supply. (Actually it is an ATX 12V 2.x)
Used
in a LOT of personal computers out there, and is readily available.
It's
a 300 Watt unit.
(The ATX form factor for this Power Supply, (Size and
shape), is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches
Tall)
Power cables from the Power Supply needed are;
A) 24-pin ATX main
power cable (Main power cable to motherboard)
B) 4-pin ATX +12 Volt
power cable, (Also known as P4)
C) At least one SATA power cable for the
SATA harddrive, and additional SATA power cables, for each SATA optical
drive.
(Your Presario may have come with SATA optical drive/s, or IDE
{PATA} optical drive/s. Optical drive = CD/DVD drive)
D) If your
Presario came with IDE, (Also known as PATA), optical drives, you'll
need a standard 4-pin Peripheral power cable, for each drive.
E) The
computer case fans, may each use a standard 4-pin Peripheral power
cable. (The Processor fan attaches to the Motherboard)
F) The Memory
Card Reader needs a Floppy Drive power cable. An auxiliary power cable.
An example of a compatible Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4465483&CatId=1079(Wasn't supposed to be stated as a Clarification)
