20 Most Recent
Goodman CKL42AR42 Air Conditioner Questions & Answers
My goodman ac not working outside
check to seif you have 240 and 24 volts available at unit. remember electricity kills. if you are not qualified to check it get a professional.
8/11/2015 10:26:42 AM •
Goodman...
Answered
on Aug 11, 2015
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
8/9/2015 7:17:00 AM •
Goodman...
Answered
on Aug 09, 2015
Very loud "squealing" noise from fan blower for
Hello, if you cannot turn the fan by hand then the motor is shot. However, when power is applied to the motor and it starts after you give it a push then its the capacitor. Whenever you replace a motor tje capacitor must be replaced aswell because the microfarad rating of tne capacitor may have changed.
5/5/2015 3:19:15 AM •
Goodman...
Answered
on May 05, 2015
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
5/5/2015 2:39:14 AM •
Goodman...
Answered
on May 05, 2015
Fan stopped running and is hot
Hello, try spinning the fan blade with a thin object such a a stick or long screwdriver, if this gets the motor running the capacitor must be replaced. If it does not get it going the motor is fualty and will have to be replaced.
5/4/2015 10:06:19 PM •
Goodman...
Answered
on May 04, 2015
My Goodman a/c unit will not turn on ..
You have a short circuit in the outside system. Either a bad compressor,bad fan motor or possibly a bad capacitor. Visually examine the capacitor. If it is bulged out anywhere,replace it. Check for burned wires on the capacitor and all other connections.
Remove the compressors wires from the circuit and restart the unit. If the fan runs the problem is in the compressor. If the fan does not run,the problem is with the fan motor.
12/15/2014 7:58:47 PM •
Goodman...
Answered
on Dec 15, 2014
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced,
home systems, packaged or otherwise are hermetically sealed and should
not need freon recharge. Always start with airflow and/or unit being set
too low. An AC unit of any type will build ice if a) the filter is
plugged up and can't move enough air, b) it has been run without the
filter, clogging the coil, again, not moving enough air, c) setting an
AC unit below 68 degrees F will almost ALWAYS cause icing, and d)
running a standard AC when it's warm inside and cold outside (unless
equipped for "low-ambient operation"). When in doubt, a bit of
maintenance(thorough cleaning) by someone with AC skills can cure a b,
common sense will cure c d.
Reply
8/15/2014 3:43:38 PM •
Goodman...
Answered
on Aug 15, 2014
R-22
65 psi on the big line in cooling is kinda close but this greatly depends on indoor and outdoor temps
5/16/2014 6:05:46 AM •
Goodman...
Answered
on May 16, 2014
Puron leak
not all electronic leak detectors pick up r410a-puron. Evaporator coils are notorious for leaking puron. your coil should be under warranty.
10/27/2013 9:52:47 PM •
Goodman...
Answered
on Oct 27, 2013
