20 Most Recent eMachines T5048 PC Desktop Questions & Answers
What if computer will not take password to your account
If you forgot your BIOS password. see this... http://www.wikihow.com/Break-a-BIOS-Password If you forgot your windows Account Login password, the following page is a good description of your choices... http://pcsupport.about.com/od/tipstricks/tp/find-lost-windows-passwords.htm Also, check out... http://ophcrack.sourceforge.net/ If the above does not work, and you have important files that you don't want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. At least you may not lose you files. Good luck G
7/30/2014 10:32:19 PM • eMachines T5048 ... • Answered on Jul 30, 2014
0answers
2answers
Do I need a USB adapter to connect to a wireless network?
You need a wireless card. It could internal or external as a USB device.
12/27/2013 3:56:34 PM • eMachines T5048 ... • Answered on Dec 27, 2013
Random shut off. Sounds like a relay click.
Could be due to getting too hot! Do you have it clear from any walls and or other PC products? If so give it some room to breath!! I have had my New Asus gaming tower turn off on me due to it getting too warm. I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
12/23/2013 12:05:21 PM • eMachines T5048 ... • Answered on Dec 23, 2013
2answers
How do you remove case from
Here is the solution:1) Close out any open applications and restart the computer.2) As the machine boots up (at the eMachines logo), press F2 (to enter the BIOS).3) Once you are in the BIOS, navigate (use the keyboard directional arrows) to the Exit Tab.4) Under the Exit Tab, choose "Load Optimal Defaults". When you are asked to confirm, select "Y" (for "yes").5) Save the changes and Exit the BIOS.6) No more loud fan!! Awesome!
10/18/2013 12:46:46 PM • eMachines T5048 ... • Answered on Oct 18, 2013
The pc starts and loads.Then the blue windows xp
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.If you able to start in the safe mode then you need to update all your drivers and install all windows updates from Windows update and scan your computer for viruses!And I also suggest you to run CMD as administrator and write in CMD without quotes"sfc/scannow" this will fix blue screen error.If problem still exists, then get the reliable program like PC Fresher to fix your annoying blue screen problem.
9/19/2013 10:14:59 AM • eMachines T5048 ... • Answered on Sep 19, 2013
3answers
I forgot My password to
You could try to use Windows Password Buster. This software can help you recover your password.Here's the tutorial: http://www.password-buster.com/reset-windows-local-password.html
8/30/2013 5:06:56 AM • eMachines T5048 ... • Answered on Aug 30, 2013
2answers
New cpu fan has 3 prong connecter, old has 4. what
You can connect the CPU fan as normal but it can only run at one speed and voltage hence only having 3 wires.
Your other CPU fan which had 4 wire was able to run at 2 different voltages and speeds and are mainly used to keep the noise down and run quietly.
Regards.
2/18/2013 11:44:09 AM • eMachines T5048 ... • Answered on Feb 18, 2013
How to open dvd door on the t5082
you can force open the dvd rom door from usinga pin 1:find the hole in your dvd rom 2:Enter a long pin in the hole3:push the pin with normal forceits done
10/7/2012 11:07:13 AM • eMachines T5048 ... • Answered on Oct 07, 2012
No signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
5/20/2012 5:29:27 PM • eMachines T5048 ... • Answered on May 20, 2012
Pxe-mof exiting pxe rom
If you are not booting from a network, PXE-boot is the wrong boot option. You have to change the boot order so that the PC will boot from your HDD. This can be set in the boot option in your BIOS.Depending on the type of BIOS, you will enter F2 or Delete during the POST( when the white letters appear on the screen after you turned it on). This will enter you into the BIOS setup. boot options are usaully the last tab. Either disable the PXE-boot or change the priority so that it boots from the HDD first. Please, if you are unformiliar with this, reference the manual or ask someone with some IT background.If the problem still exists after you configured the boot options your hard disk drive might not be readable. The BIOS just goes to the next availible boot device.
4/24/2012 2:52:52 PM • eMachines T5048 ... • Answered on Apr 24, 2012
I installed realtek driver but i hear no sound
OK--first, is it the correct driver for your computer?Now be sure your speakers are plugged into the green port.If the speakers are powered, are they turned on?Check the speaker icon in your system tray--lower right side of the screen. Click on it to see if the sound is too low or maybe muted.If still no sound, go to the control panel and click on the sound icon. In that window you click on "sounds" and see if you can click on a sound and play it. If the "play" arrow is gray, it means your sound card drivers are not installed. You can also make sure that your speakers are the devices selected to play the sounds.Another thought? The speakers are bad.
3/5/2012 7:56:37 PM • eMachines T5048 ... • Answered on Mar 05, 2012
How To Remove Front Panel For t5048 Emachines Tower
The eMachines T5048 Desktop PC, uses the NexGen 2 computer case.(Also uses an Intel D102GGC2 motherboard)1) http://www.hypermicro.com/mmhypermicrocom/images/CSEC004.JPGThe front panel is the Front Bezel.It is removed by grasping the right side of it, and pulling out, G-E-N-T-L-YThere Power On switch wires, Power On LED wires, USB front panel wires, Card Reader wires, etc., are still attached.http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf(Page 47 - Removing the Front Bezel ){ Note*Usually there are plastic tabs formed out of the Front Panel, and they snap into slots in the metal computer case frame.Usually 3 per side. They are flat, and have a hooked end.They are pressed to the outside, or inside of the case, to release the hooked end away from the side of the slot.LOOK at the tab. Look at the hooked end. SEE which direction THAT flat tab should be eased over to, in order to bring the hooked end away from the side of the slotted hole.When the hooked end is in the middle of the slotted hole, the flat tab can then be eased OUT of the slotted hole.DO NOT assume all tabs go in the same direction }[ The area of contact pins on the motherboard, that the wires from the Front Panel go to, (Except for the USB and Card Reader), is the Front Panel header.This link shows you the Front Panel header pinout,http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-022441.htmClick on the blue file name -Intel Desktop Board D102GGC2 Product Guide - English (PDF){It's a Motherboard User Manual }For additional questions please post in a Comment.Regards,joecoolvette
2/4/2012 7:05:47 PM • eMachines T5048 ... • Answered on Feb 04, 2012
How do i reset my emachine t5048 to factory
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
10/22/2011 5:42:03 AM • eMachines T5048 ... • Answered on Oct 22, 2011
Added 2 1GB memory to
There are two variants of the T5048 One uses DDR PC3200 ram the other uses DDR2 PC5300
Should be able to look at the old ram and it should say on it what it is. If it doesn't, take out the new, put in the old ram and go here http://www.crucial.com/store/drammemory.aspx Run the "Scan My Computer"
Some computers will have a setting in BIOS to disable on board video although eMachine are very low end and probably don't offer that. Shouldn't need to just install your video card and plug your monitor into it. It should work just fine without disabling on board.
Comment if you need more help
9/11/2011 11:49:55 PM • eMachines T5048 ... • Answered on Sep 11, 2011
2answers
What type of ram do i need to use?
Your eMachines T5048 PC Desktop uses RAM of specification DDR400 which is also called PC3200. DDR Stands for Double Data Rate.
Your computer is expandable to a maximum of 2GB
Take care!
damnor01
6/9/2011 3:14:25 PM • eMachines T5048 ... • Answered on Jun 09, 2011
eMachines T5048  PC Desktop Logo
52 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
pc starts loads blue windows xp
  • Computers & Internet
