If you have forgotten your password if you have another user account with administrative privileges you can log into that account and change your original user accounts password from the User Accounts applet in Control Panel.
If you dont have another account like this set up or dont have the password to it you will need to log into the built-in Administrator account.
In XP Home boot the computer into Safe Mode.
Do this by repeatedly tapping the F8 key as the computer is starting up.
This will get you to the right menu
Navigate using your Up arrow key the mouse will not work here
Once in Safe Mode you will see the normally hidden Administrator account
The default password is a blankIn XP Pro you do not need to go into Safe Mode
At the Welcome Screen do Ctrl-Alt-Del twice to get the classic Windows logon box.
Type in "Administrator" and whatever password you assigned when you set up Windows.If you reset the built-in Administrator accounts password in Home or have Pro and dont remember the password there are ways to change the password for that account to a blank
hope this helps
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cablesAnothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
24 questions posted
52 Questions
44 Questions
42 Questions
29 Questions
