20 Most Recent eMachines T3604 PC Desktop Questions & Answers
If your computer is less than a year old, you should be able to contact Dell technical support for help (support.dell.com)
It sounds like it's a driver issue - most likely video drivers. You can check the support website for updated drivers for your video card.
eMachines T3604... | Answered on Dec 20, 2016
You will need to change the boot order in the bios set-up.
Turn your computer off, and turn it n again (alternatively Restart it) These things may be initiated by clicking the Windows button at the bottom left of tour screen, and from the shut down drop down menu selecting the appropriate option) As your computer is starting up, and the Emachines logo appears on the screen
"Press the "Tab" key repetitatively: If that fails to take you into the BIOSsetup, repeat and try either the "Escape," "Delete," or "F2" keys instead of the Tab key.
Once in the BIOS setu[p, Look through the options until see Boot order, and then change that to CD first, HD 2nd. Exit the BIOS setup with save changes option. Done.
19.February.2015
eMachines T3604... | Answered on Feb 19, 2015
open your boot screen setup and update your bios, it'll fix its self.
eMachines T3604... | Answered on Aug 08, 2014
Sounds like a "Power On Password" and you'll need it to continue. You can try pressing "Enter" with the field bland and if there was no password set, it should continue to load windows.
Please clarify if I misunderstood your issue?
eMachines T3604... | Answered on Mar 02, 2014
Buy a card reader.
eMachines T3604... | Answered on Oct 16, 2013
The eMachines T3604 Desktop PC uses an Intel D945GCL motherboard,
http://www.ascendtech.us/intel-d945gcl-1066fsb-ddr2-pcie-x16-sata_i_mb4intd945gcl.aspx
Read what you stated. Just posting for visual corroboration.
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gcl
http://www.intel.com/support/motherboards/desktop/sb/CS-022312.htm
Yes,.....a pre-built computer company has a BIOS program written especially for them. That is, for each model line of computer........
..............GENERALLY..............
However, IMHO I think the standardized Intel BIOS program was used, and not specific to eMachines, or this model line.
Just an assumption, and you know what they say about assuming.
I leave it in your capable hands.
Regards,
joecoolvette
eMachines T3604... | Answered on Apr 08, 2013
The eMachines T3604 desktop computer uses an Intel 945GCL motherboard,
(No, not advertising. Just a good photo of the motherboard, if you slightly scroll down)
Look at the chart below the photo of the mobo. (MOtherBOard)
Expansion Capabilities:
A) Two PCI slots (Two PCI Conventional bus connectors. Long white slots)
B) One PCI Express x1 bus add-in card connector.
(PCI Express x1 slot. The longer PCI-Express x16 slot is on top.
Then the two long white PCI slots. Then the shorter black PCI-Express x1 slot)
You can use a Sound Card in an available white PCI slot, or if the black PCI-Express x1 slot is open.
Yes, I know, I'm getting to it, lol!
The Onboard Audio -> Intel High Definition Audio, doesn't have an output mixer feature.
My onboard audio - Realtek, (And on an Intel mobo), does.
[ Intel 915G (Southlake) motherboard.
Has a Realtek audio chip, ALC860. I use the Realtek Audio Manager. Has Sound Effects, and an equalizer.
What happened from the Intel 915G to the Intel 945GCL INTEL?
Sheesh! ]
Suggest this if you have an open, available PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4459743&CatId=2771
This, if you only have the PCI Express x1 slot open,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=420799&CatId=2771
I don't recommend a USB sound card, but you may,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5344879&CatId=2771
(Usually only 16-bit.
Plugs into a USB port where the contacts are not gold plated, as on a PCI sound card, or PCI-Express x1 sound card.
I'm old school, and probably need to evolve ; )
Plus use Virtual DJ,
http://www.virtualdj.com/download/free.html
Mixing Tips;
1) http://www.youtube.com/watch?v=dkGAFTXidKs&feature=related
2) http://www.youtube.com/watch?v=FQ62zoVIKB4&feature=related
3) http://www.youtube.com/watch?v=nn6nsXpX7bU&feature=related
Regards,
joecoolvette
eMachines T3604... | Answered on Jun 24, 2012
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
eMachines T3604... | Answered on Mar 24, 2012
get the user manual and it will provide you all necessary information.
download it from here,
http://www.retrevo.com/support/eMachines-T3604-Desktops-manual/id/4870bh045/t/2/
best of luck!
eMachines T3604... | Answered on Feb 16, 2012
Telephone eMachines, and order a replacement "System Recovery" set of CDs. Given the serial-number and model-number of your computer, they know what O.S. originally was factory-shipped with your computer, and they will replace that part.
Probably, a small fee for courier-shipping.
eMachines T3604... | Answered on Dec 03, 2011
There should be a 4 pin black or white connector that has CD printed next to it.
eMachines T3604... | Answered on May 03, 2011
Theres no specific order for power supply wires. Just make sure it is disconnected from a power source and connect the Motherboard and optical drive cables to their respective plugs(plugs are standard for most motherboards).
eMachines T3604... | Answered on Mar 03, 2011
New hard drive $40 to $60.. www.Tigerdirect.com www.frys.com www.bestbuy.com etc..
Main thing you need to know is SATA or IDE (aka .. PATA) Sata or serial uses small half inch wide cables . IDE / PATA uses 3inch wide ribbon cables. Pop the PC open andlook at the hard drive to see the cables attached. Most new drives come with basic instructions.
eMachines T3604... | Answered on Feb 23, 2011
try F8 when the computer is booting. This should take you to an optional start up menu. Try the safe mode. Did you recently install any devices or software? If you did in safe mode remove them and reboot. Should fix the problem
eMachines T3604... | Answered on Feb 06, 2011
you can purchase a pci express x16 video card. It installs in the pci express x 16 slot on the motherboard
eMachines T3604... | Answered on Feb 05, 2011
Pressing the DEL key when starting up as the Emahine logo appears, but before Windows starts up..
eMachines T3604... | Answered on Jan 16, 2011
it looks like your hard drive may have gone bad.
eMachines T3604... | Answered on Dec 23, 2010
eMachines T3604 PC Desktop Logo
Popular Tags
65 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
replace graphics card
  • Computers & Internet
