20 Most Recent eMachines W3611 PC Desktop Questions & Answers
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
7/18/2017 1:44:35 PM • eMachines W3611... • Answered on Jul 18, 2017
Monitor says no signal when turned on
Check the memory cards are inserted correctly (remove and reseat)
12/27/2013 8:18:46 PM • eMachines W3611... • Answered on Dec 27, 2013
Restore emachine factory settings
Do a system restore point/date and see if that will take your PC back to where all your settings were at and what you liked at the time before you made the change. I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
12/23/2013 11:43:23 AM • eMachines W3611... • Answered on Dec 23, 2013
2answers
Password reset
Reset desktop password with Smartkey Windows Password Recovery by the following steps,Step1: Download Smartkey Windows Password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.Step2: Install and launch it to any accessible computer.Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.Step4: Boot the locked computer from CD/DVD/USB.Step5: Start to reset desktop password with the burned disk.Step6: Reboot computer and login to the locked PC without password.
7/11/2012 10:07:05 AM • eMachines W3611... • Answered on Jul 11, 2012
2answers
How to remove startup password
If it's a Bios Password, then you can remove the power cord, remove the case, turn the computer on it's side and look for the CMOS battery. It is a silver battery on the motherboard about the size of a nickel. Use a small flat head screw drive to pop it out. Let the computer sit for an hour or two then put the battery back in and reboot. The date, time and password will be forgotten by the system, so you will have to go into the Bios or System Setup to put the date and time back in.If it is a Hard Drive Password, you are out of luck. 99% of the time when you encounter a computer with a Hard Drive Password on it, the computer is stole. The original owner set it so that in the event the computer is stolen, thieves can't get to sensitive data. The owner could possibly set it remotely after it was stolen. The only way to remove it is have the original owner put in the password,or like you did when you put in another hard drive. Putting in another hard drive in most cases you will have to reload the operating system, drivers and application programs.
4/7/2012 7:36:34 AM • eMachines W3611... • Answered on Apr 07, 2012
How do i totally factory
You'll need a copy of Windows. Microsoft has guides on how to install and uninstall all windows versions here: http://windows.microsoft.com/en-US/windows/help/install-reinstall-uninstall
8/17/2011 3:47:37 PM • eMachines W3611... • Answered on Aug 17, 2011
My computer does not produce
Have had a look at your drivers to see if they are ok? what happened before this behavior started?
4/26/2011 9:27:15 AM • eMachines W3611... • Answered on Apr 26, 2011
I tried to do a
You have to keep pressing it during the boot sequence. Can you get F8 to work? You can try having windows restore your last known good configuration.
4/15/2011 2:38:40 AM • eMachines W3611... • Answered on Apr 15, 2011
Ask for password to unlock system
Just hit the set up key as your machine boots up, usually, F2-F3 or F8.
Go to safe mode using the up-down arrows and where it says set/change password, simply hit the enter button, enter a new password in and close, using the save function.
You can now use that new password and are now officially the administrator!
Or else, you need some Windows password reset program to help you do that job.
11/26/2010 6:14:03 AM • eMachines W3611... • Answered on Nov 26, 2010
This machine came with Windows Vista installed and
fastest way to tell is for you to take the side panal of and look at the motherboard the make and model are printed on all boards the main manufacture is dell
10/25/2010 4:32:45 PM • eMachines W3611... • Answered on Oct 25, 2010
I need to restore it
If you don't have a recovery disk, which they usually don't provide anymore, you can make one if the computer is still working properly. Type" recovery disk" into help & it should walk you thru it. Otherwise you can call or email the maker of the computer, which I think is gateway & order one. Then put it in the computer, restart & it should walk itself thru. You make have to go to setup when the computer first boots up & make sure it goes to the dvd drive first.
10/20/2010 8:12:31 PM • eMachines W3611... • Answered on Oct 20, 2010
Upgraded memory in W3611. Won't start. Gives
Remove RAM(S), clean the ram slot by blowing air, fix RAM(s) back in position untill both the side clamps are properly locked.
If problem persists try resetting motherboard via jumper pins on the motherboard.
9/3/2010 12:48:08 PM • eMachines W3611... • Answered on Sep 03, 2010
I DONT KNOW HOW TO PUT THE CARD IN IT
Tiffano,
You have not specified what card you want inserted. Anyway.
Please remove the 3 screws at the back of the PC on the right side of the PC as you face to back. This will enable you to remove the cover thus exposing the innards of the PC. You will find at least one slot empty for a cord to be inserted. Insert the card with its contact lugs towards the motherboard and the metallic strip towards the back.. Fit it properly and tighten the screw on top of the metallic strip to the body of the computer. Once done, screwup the side plate of the PC and turn it around to face you. Now insert the CD that came with the card and install the card.
Now you are ready to use the card.
3/5/2010 6:08:50 AM • eMachines W3611... • Answered on Mar 05, 2010
2answers
3 beeps when powering up, no video
Re-fix the RAM sticks and restart your PC .it will work
2/18/2010 3:05:06 PM • eMachines W3611... • Answered on Feb 18, 2010
2answers
Cannot remove websites from my favorites.
You might need Administrator permission.Make sure you have administrator rights. place curser on drop down URL and press right key mouse button select run as adminiistrator then try to deleate with right mouse button menue.
11/9/2009 12:17:58 AM • eMachines W3611... • Answered on Nov 09, 2009
2answers
There is no signal getting to from my computer to
It is the video card!
So, when you plug the monitor in to the rear of the eMachine case, do you connect it in the aread where the keyboard mouse and USB and sound conntors are OR do you connect to the area when all the expansion slot covers are?
If you answered YES to the first part of the question, then the video signal comes from an 'integrated' video card that is part of the mainboard. This is bad. Contact eMachines in order todetermine if the system will allow a video card to be installed in an expansion slot...
If the second part of the quetion is YES, this is better. You can replace the video card andprobably be OK. Get you teenager to open up the case and pull out the video card. You need a new one but they come in multiple 'types' so you need some to have look at it and sell you another compatible one.
10/13/2009 9:44:01 PM • eMachines W3611... • Answered on Oct 13, 2009
I AM HAVING TROUBLE WITH FIREFOX/JAVA. I KEEP
Java is your first problem get rid of that malware... second problem is you don't have a mac, haha, just kidding, but seriously get one.
To answer your question, I would try uninstalling your add ons 1 or 2 at a time to see which one will fix er back up. If that does not work, get Revo uninstaller from download.com and use it remove firefox (and java) completely. You can download the newest version any time for free. Personally I dont like a lot of background processes so I use the portable version of firefox which is also free.
9/21/2009 7:33:33 AM • eMachines W3611... • Answered on Sep 21, 2009
Freezes while trying to do fresh install from
this indicates a bad hard drive, or Ram or both
7/29/2009 3:29:27 PM • eMachines W3611... • Answered on Jul 29, 2009
Motherboar reconected
Remove the hood, and double check that all of the cords and wires are correctly plugged in and secure. Hope this helps, Thanks
6/28/2009 12:12:27 AM • eMachines W3611... • Answered on Jun 28, 2009
2answers
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
5/30/2009 7:13:03 AM • eMachines W3611... • Answered on May 30, 2009
eMachines W3611 PC Desktop Logo
36 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W eMachines
  • W eMachines
Most Popular Question
  • Computers & Internet
