20 Most Recent
Dell Vostro 220 Desktop Computer Questions & Answers
Reset bios
You don't reset bios. If you can't boot, replace the coin cell battery on the motherboard.
Disk drawer stuck
Look for a tiny hole on the face of the CD drawer. Straighten a paper clip and push it in the hole. This will manually open the drawer.
How to solve the following error message: Not enough space in runtime area !!! smbios data will not be available, and then locks the keyboard. how can I flash or update the bios if I can't use the key
This may be a failed Bios update.
See this...
https://answers.yahoo.com/question/index?qid=20140218071633AApHjUR
Also, the hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer.
Hi,i have purchased a new computer and I do not
Create a archive of your mail through outlook and paste that in the new computer and configure the outlook in your new computer and browse the archive. If some issue is coming then comment on this.
Dell Vostro 220 won't turn on. Checked plug with
Usually that happens when there is a power spike and the internal resistance gets fried. It's easily replaceable by anyone with medium to high technical skills but I recommend sending it to be serviced (especially if you're in warranty). This resistance's purpose is to protect the motherboard (it fries so that the motherboard doesn't) so don't worry, it's nothing major.
LENOVO K410 CD TRAY WONT EJECT MANUALY
Using a paper clip one can eject the drive tray.Bend a paper clip into a straight length of around 2"(inches).Push the end into the little hole found on the front of the drive, below the tray.Your tray will now unlock, pull the tray to side it out.Easy and you are done.Take care!damnor01
Scroll bar is off the screen
Hi,1) What is your screen resolution?2) When did this start to happen?3) What did you do when this started to happen?
My scoll bar is not showing on my main screen. How do I adjust to have it fit?
Kim Drader,Below are steps to resolve your scroll bar issue.
Instructions
Restart your computer Sometimes, a simple restart can bring back the scroll bar to its original form.
Right-click anywhere on your desktop. Click on "Properties" if you are using Windows XP. Select "Personalize" if you use Windows Vista or Windows 7 and click on "Windows Color and Appearance." Then click on "Open classic appearance properties for more color options."
Click on the "Advanced" button.
Click on the "Item" drop-down menu. Select "Scroll bar."
Change the width by entering "17" under the "Size" category. 17 is the default scroll bar width for Windows operating system
Click on "OK" and select "Apply" to end task.
Thank You,Dell-Jesse LDell Social Media and Communities
I dont remember my administrator password how can i reset my computer
If you failed to create a password disk for your computer uyou may be able to recover your password, if not reset it. I am going to assume you are on windows 7 as you did not specify. Search for "Bootable windows 7 password recovery disk" alternativly try here: http://techrena.net/reset-windows-xp-vista-7-password-usb-pen-drive-cd/I do not endorse this link or the software provided therein and neither Fixya nor I will not be held responsible for the end use of the software.ALWAYS try to recover rather than reset the password. If you reset the password you may loose access to encrypted files.
