20 Most Recent
George Foreman GGR50B Grill Questions & Answers
Why does my battery charger turn on when plugged and after 6 seconds turns off?
could be a circuit protection device
check correct battery voltage selected
check correct t battery post connection positive to positive -negative to negative
check that the clips are on the battery posts as there may be a build up between the posts and the terminals that is causing the charger to overload or sense an open circuit because of the high resistance
I need a replacement handel for my grill.
Good Day Gfranks100!
Is it correct that you are looking for a replacement handle for a George Foreman GGR50B Grill?
If not, please state here the brand and model of your grill so we could refer you directly where to purchase the part.
What # should i use
To first sear the steak on both sides, turn it to it's highest setting. After both sides have seared for about 3-5 minutes per side, depending on the thickness. Then turn the temp down to medium and continue to grill to the way you like it turning it once more. Never use a fork to turn the meat. It pierces it and allows those wonderful juices to drain out. Use tongs instead. Once it's cooked to your liking, take it Off the grill and allow it to rest 3-5 minutes. That way, when you cut into it, most of those wonderful juices will remain in the meat.
Hope this helped you and enjoy your steak! Happy grilling!
