20 Most Recent
Canon PIXMA MX7600 Multifunction inkjet Questions & Answers
Error code b300
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Need black ink refill
cartridge also compatible with pro9500. inkoasis.com will get both original and compatible cartridges to you within a day or two. seem to work fine. much less expensive than originals. Staples will also get you a cartridge delivered directly to store for pickup even though they do not usually carry it.
PRINTING BLANK SHEETS
If
an inkjet printer has not been used for some time and several print
head deep cleaning has been done and it still does not print properly then
the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But
these print heads are expensive to replace, it may be better to buy a
better and a later model printer for not much more costs.
I replaced the clear ink tank on mx7600 and the
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Scanning a document from the ADF results in a line
Lift the scanner cover so that you can see the platen glass. Look to the left of the large sheet of glass and you will see a narrow strip of glass. This is the area used to scan documents fed from the ADF. Make sure that this glass is very clean. Use a damp cloth to clean any dirt or buildup.
Have a code 100 what do i do
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
try at another fax, if it fails you need to get your printer to service station.
