20 Most Recent
Kyocera FS-3830N Laser Printer Questions & Answers
Install MK? What does this mean?
Its because you've gone past a certain number of pages printed.
Its asking you to install a new Media Kit
To reset the message -
1 Press the MENU key.
2 Press the or key repeatedly until Life Counters > appears.
3 Press the > key.
4 Press the or key repeatedly until >New Toner Installed. appears
5 Press the ENTER key. A question mark (?) appears.
6 Press the ENTER key.
The toner counter is reset. The message display returns to Ready.
TRYING TO CHANGE THE DRUM
Open the top door
remove the toner cartridge
unplug the DV unit plug on left side
move spring loaded gray lever to the rear and hold
grasp the vertical part of the DV unit , lift up and out
open left door
remove the waste bottle
push small gray button on drum and pull drum out
remove tape on new drum carefully
reverse procedure to install.
