20 Most Recent
Canon PIXMA iP1300 Printer Questions & Answers
My printer claims it does not recognize the color
GENERAL PRINTER TROUBLESHOOTING ADVISE ON INK:
Open the printer and remove the ink. Clean around the ink carriage and
the under the ink with alcohol and a cotton swab. Pay special attention
to areas with copper contacts. Keep
in mind too that some printers will not print, even with full ink, if
the exact type of ink it expected you to have installed is not right. Double
check that the ink is correct against the manual or written
instructions inside the printer using the number not the shape. Not every cartridge that fits the
printer necessarily works.
The printer doesn't print.
The print head indexing is off. Probably slipped on the cog. A factory service might be able to fix it, but it'd probably be less expensive to replace it.
Canon pixma ip1300 cant detect ink cartridges
remove all the cartridges. using tissue or cotton cloth.. dub the connectors to the cartridge of the printer.. then wipe the cartridge connector area dry. if this does not work, you need new cartridges. with new cartridges and the same problem persist, your printer has the problem on the in decoder strip. area. hope to be of help.
The ink cartridge cannot recognized (refilled 3 times)
i am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that
should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
