20 Most Recent Canon iR 2022 Printer Questions & Answers
Memory full canon ir 2525
may be u can change the memory
3/12/2019 5:16:31 AM • Canon iR 2022... • Answered on Mar 12, 2019
Ircaon2022n show disply loud currect paper sise hari rewari
my dear selact A4 paper size
1/12/2018 9:22:15 AM • Canon iR 2022... • Answered on Jan 12, 2018
4answers
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
9/13/2017 12:48:32 PM • Canon iR 2022... • Answered on Sep 13, 2017
I have canon iR2022 someone help me for setting A4 paper.when i m printing its taking A3 by itself.
You must adjust your paper size in casset .in canon 2022 look to your machin casset left . You see how to adjust
11/8/2016 7:59:19 PM • Canon iR 2022... • Answered on Nov 08, 2016
manual
How i do scanner in canon ir2022
connect computer to networkinstall canon color network scangear, select printer ip in this software.now you need scanning software. I'm using freekapture.place document in printer scanner. click scan button on printer.open freekapture and start scanning
1/28/2016 10:39:58 AM • Canon iR 2022... • Answered on Jan 28, 2016
Ircanon2022n loud currect paper sise on disply
my dear selct a4 paper size
8/12/2015 3:26:02 PM • Canon iR 2022... • Answered on Aug 12, 2015
How to clear the message "the scanning area is dirty"
in the panel press: aditional function/common setting/ADF dirty dysplay/ do not display
4/28/2015 1:06:10 PM • Canon iR 2022... • Answered on Apr 28, 2015
Printing Problem,finish product have line
This is usually caused by dirt. It can be on one of the paper rolls in the printer, toner etc. I suggest you run the cleaning program.
4/20/2015 1:02:31 AM • Canon iR 2022... • Answered on Apr 20, 2015
2answers
How can I fix an error code E007 on a canon IR2022 copier?
E007 0000- An error in the rotation of the fixing film is detected. The reading of the main thermistor is 100C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven. Main cause- The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty. Caution- To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. Action ------------------------------------------------------------------------------- 1. Wiring Are the wring and the connectors connected securely? DC controller PCB (J311) <-> relay connector <-> fixing film sensor NO:Connect the wiring and the connectors. ------------------------------------------------------------------------------- 2. Fixing film sensor Check the fixing film rotation signal.When the fixing motor is rotating, is the film rotation detection signal sent by the fixing film sensor to the concoctor J311 of the DC controller PCB? Film rotation detection signal:5V pulse signal between J311-A9 (FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440 msec OFF NO:If the fixing film is normal, replace the sensor. ------------------------------------------------------------------------------- 3. Fixing film unit, DC controller PCB Is there a fault in the fixing film edge rotation detection mechanism? YES:Replace the fixing film unit. NO:Replace the DC controller PCB. =============================================== Execute the following in service mode, and turn off and then on the power switch to clear the memory: #7 PRINTER>#4 PRINTER RESET>YES=(*) Try this - Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key. Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1). Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
7/19/2014 4:03:54 PM • Canon iR 2022... • Answered on Jul 19, 2014
System error E007 Canon IR2022 whit is prablume
Error Code, Sub Code, Code Explanation E007 0000 Fixing film sensor failure The fixing film sensor is faulty. Before you replace the fixing film sensor, you might wanna try this first! Download and install the newest version of the printer driver. If that doesn't help then check the papers size. If you are using A4, then you have to make sure that it is actually the correct dimensions. the link below might help you with that. Welcome to A4PaperSize org
7/6/2014 1:14:26 PM • Canon iR 2022... • Answered on Jul 06, 2014
Ir2022 system error e007 vido
Error Code, Sub Code, Code Explanation E007 0000 Fixing film sensor failure The fixing film sensor is faulty. Before you change the fixing film, then download and install the newest driver for this printer. If that doesn't work, then check if the paper size is correct. It might be on A4, but you have to check if the dimensions are correct. This might help with the dimensions Welcome to A4PaperSize org
7/6/2014 1:10:39 PM • Canon iR 2022... • Answered on Jul 06, 2014
0answers
Check Printer Cover' message
check the plastic tab to be sure it is not broken where the switch is
6/20/2014 8:35:08 AM • Canon iR 2022... • Answered on Jun 20, 2014
0answers
Canon iR 2022 Printer Logo
213 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon irt 2022 says system error 007
  • Office Equipment & Supplies
