20 Most Recent HP J4680 Office Jet All-In-One Printer Questions & Answers
2answers
Why does my printer say its offline? printer says
To resolve the issue, follow the below steps:
Follow the weblink
Rather that sending you steps in text, i will refer u to the weblink. Where all the info is explained with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02221706&cc=us&lc=en&dlc=en&product=3692888
click on the weblink and follow the steps.
7/8/2019 11:16:50 AM • HP J4680 Office... • Answered on Jul 08, 2019
I have a macbook pro
If everything is ok and printer is not printing it needs to be checked manually now. you need to check printer settings to make it online. Hope it will start working. If you wish you can contact me at +1631-855-3940 or through IMO app +918510879267
2/17/2018 7:35:23 AM • HP J4680 Office... • Answered on Feb 17, 2018
HP officejet j4580 All-in one
That suggests either a faulty sensor or there really is stuck paper... a piece smaller than your little fingernail could jam many printers. If you can't see inside the thing, a vacuum cleaner with a blow function might help... but try that only through a filter
11/6/2017 1:36:49 PM • HP J4680 Office... • Answered on Nov 06, 2017
0answers
Bad print head on my hp officejet j4680 all-in-one
Being six years old it's probably got a fair amount of crud built-up. I generally remove the print head, on printers that have this ability, and then clean with some qtips and 90% isopropyl alcohol. If that doesn't fix it and a replacement print head is available then replace it. But consider the cost, as cheap as printers are these days you don't want to put a lot of money into a six year old printer when you can replace it just as cheaply.
11/25/2015 10:09:24 AM • HP J4680 Office... • Answered on Nov 25, 2015
GOT 33 PRINT JOBS IN QUEUE L IKE TO DELETE THEM
Hi hunter707515
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
11/23/2015 10:10:15 PM • HP J4680 Office... • Answered on Nov 23, 2015
Hpj4680 won't connect wireless to network,
I had the same problem , I entered the configuration of my linksys router and changed from mixed to B+G in the wireless tab and after that, no more problem, it connected rigth away
3/23/2015 5:11:16 PM • HP J4680 Office... • Answered on Mar 23, 2015
What is causing my printer to says paper jam and there isn't one. what is causing this problem
Frequently the feed roller will wear out and not pick up paper. Check for slight smudge mark on the paper. The machine will identify a jam if the paper does not reach a sensor.
2/18/2015 8:13:41 PM • HP J4680 Office... • Answered on Feb 18, 2015
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
1/4/2015 2:47:38 AM • HP J4680 Office... • Answered on Jan 04, 2015
Get the orange plastic top off the black ink cartridge
With respect to your HP OJ J4680 printer, which uses HP 901/901XL ink cartridges, it sounds like this is either a compatible/clone cartridge from overseas in which case you should not remove the orange top as it is molded into the cartridge, or you recently purchased or had the ink cartridge refilled (at Costco, etc.) and the storage clip (which seals the base of the cartridges to prevent the nozzles from drying out) is attached to the ink cartridge. If this is a storage clip, just press hard on the clips top lever at an angle to remove. See our videos on cartridge care tips and how to troubleshoot an ink cartridge error/problem on the HP OJ J4500, J4600 and OJ 4500 series printer models: HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges:http://www.youtube.com/watch?v=S6uATgXxQlEIf you need to purchase new HP 901 ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20. NOTE: If you are interested in the top \'refill friendly inkjet printer models\', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585 INK REFILLING SERVICES (SUPER CHEAP):Costco USA Ink Refill Service (460+ stores): http://www.costcoinkjetrefill.com Costco Canada Ink Refill Service (59 stores): http://www.ca.costcoinkjetrefill.com Costco Mexico Ink Refill Service (35 stores): http://es.costcoinkjetrefill.com/ Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/ Fry\'s Electronics Ink Refill Service (34 stores): http://www.frys.com/ads/page51 Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/ For any additional questions you may contact us directly: [email protected] -Thank you
9/30/2014 5:55:51 AM • HP J4680 Office... • Answered on Sep 30, 2014
What do the symbols on the glass mean
yours ink cartridge printing head blocked due to ink dry in side so u have to replace inks it will be print
7/27/2014 8:45:42 PM • HP J4680 Office... • Answered on Jul 27, 2014
HP J4680 says "printing" but won't print
just check it weather it is detecting your pc or laptop. if it is detecting check it is scanning working fine or not, if it is scanning fine you need to update firmware and check it. still getting same issue you need to replace the main pca board.
6/25/2014 5:14:51 PM • HP J4680 Office... • Answered on Jun 25, 2014
Error on hp j4680 image on fax send report is set to on
Sir/Madam Solution one: Print a fax test 1.Make sure the product is turned on and correctly connected to the telephone jack. 2.Make sure that there is plain white paper in the input tray. 3.On the product control panel, press the Setup button ( ). 4.Press the right arrow ( ) to select Tools , and then press OK . 5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints. 6.Review the results of the test. ·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes. ·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution. 7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution. In case You Still facing Problem The Visit official HP Printer website Below URL Link On: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888 OR If you Still having Problem then follow Us On: HP Printer Support
2/12/2014 8:42:25 PM • HP J4680 Office... • Answered on Feb 12, 2014
HP J4680 Office Jet All-In-One Printer Logo
428 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
need j4680 download driver
  • Office Equipment & Supplies
