20 Most Recent
HP P2035N LaserJet Monochrome Printer Questions & Answers
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
7/29/2021 8:19:51 AM •
HP P2035N...
Answered
on Jul 29, 2021
What does ! in a
The printer cartridge door is open.
Attention
The print-cartridge door is open.
Close the print-cartridge door
Attention
10/9/2019 7:17:01 PM •
HP P2035N...
Answered
on Oct 09, 2019
I want to reset my
Try RESTORE DEFAULTS
"press and hold the GO button and CANCEL button for 10 seconds while turning on the product"
4/30/2015 9:47:43 AM •
HP P2035N...
Answered
on Apr 30, 2015
HOW DO I PRINT A MIRROR IMAGE ON A HP P2035N
If the feature is offered, you should be able to choose that option in the document page setup area. I know there is usually a 'mirror margin' option in page setup. Also, the printer manual might be helpful.
3/25/2015 2:11:14 PM •
HP P2035N...
Answered
on Mar 25, 2015
52.0 scanner error
Try the toner cartridge first, it could be not opening properly, after that it will be the laser scanner assembly.
3/15/2015 10:02:43 PM •
HP P2035N...
Answered
on Mar 15, 2015
Is there a ps driver for the HP P2035n printer?
The 2035 is a GDI or host based printer. There is no actual print processor in the printer itself, all processing is done on the PC so I do not believe that you can use Post Script Drivers.
10/30/2014 4:22:51 AM •
HP P2035N...
Answered
on Oct 30, 2014
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
10/30/2014 3:52:53 AM •
HP P2035N...
Answered
on Oct 30, 2014
Print envelopes
Are you using the tray 1 manual feed for the envelopes? If it was working for you before but now has trouble feeding from that tray you are probably going to need a new PU roller and sep pad. You can try and clean the roller with a lint free cloth and use isopropyl alcohol.
9/2/2014 3:48:43 PM •
HP P2035N...
Answered
on Sep 02, 2014
HP Laserjet monochrome 1320 red light flashing on printer
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c00230632-1%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N10135 Go to this link for blinking light
6/28/2014 4:25:17 PM •
HP P2035N...
Answered
on Jun 28, 2014
P2035n printing black pages
try changing toner cartridge. If that doesn't work then you may have a bad laser or the shutter on the laser is stuck in the closed position.
4/26/2014 2:35:32 PM •
HP P2035N...
Answered
on Apr 26, 2014
How do you retrive the meter reading on HPLJP2035N
how to retrieve the meter reading-
allow the machine to come to ready-
press the down arrow on the printer keypad ( information) then press tick -
press down arrow again (configuration) press tick.
the printer now print 2-3 pages of printer configurations inc life cycles and net card configs
1/30/2014 8:45:14 AM •
HP P2035N...
Answered
on Jan 30, 2014
