20 Most Recent
Toro TimeCutter SS5000 zero turn mower Questions & Answers
Toro Timecutter SS 5000, no power flowing through the solenoid.
The automatic brake actuator provides for the start solenoid return path to battery negative, i.e. the green wire. The brake actuator must be in a "BRAKE ON" state or engine cranking is disallowed.
If you measure battery voltage at the solenoid green wire then likely the brake actuator is not in a "BRAKE ON" state.
With engine off and key in on/run position you should hear the brake actuator move from brake on/off/on with control arms out/in/out movements.
By pass fuel solenoid
are you sure that's not a fuel pump ? unless this thing runs on diesel , im pretty sure that's a fuel pump not a fuel shut off , and no ya cant run without a fuel pump , but I gotta ask do you know the exact cause of the fire ? if theres a possibility that it was the fuel pump overloaded , just hooking a hot wire to it could burn the entire machine down
