20 Most Recent
Tektronix Phaser 840DX Thermal Printer Questions & Answers
I have a tektronix 840 printer, The prints are
http://www.tek-tips.com/viewthread.cfm?qid=1284733&page=1
Above is your service and repair manual, below is your user manual, both are invaluable in troubleshooting
www.office.xerox.com/userdoc/P840/840pdf/840UG.pdf
This could indeed be the fuser, at the end, it may be dirty, or not working right at the edge, i think there is some sideways adjustment? Or it maybe the heating bar? Also I have heard of some papers being "Better" at receiving the ink, i believe a more porous paper is better?
Please use the service manual, to troubleshoot your issue, further, as unfortunately, as with most electronic things i see in my shop, the symptoms displayed often have many and various "Causes", for the exact same symptom! One simply must work through the troubles shooting steps to isolate a cause.
Printer error code 61 on
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
I have a Tektronix Phaser
This is from the 560 manual hope the codes are the
same. The 560 manual states : Accumulator belt cleaning blade movement
error.
1. inspect the cleaning blade{located on the imaging unit,along
the bottom of the green OPC belt. Is it flipped up? If you cannot flip
it down, replace the imaging unit.
2. Inspect the wiring harness
leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
