20 Most Recent
Laser Phaser 6125 Colour XEROX Phaser 6125 Colour Printer Questions & Answers
Why will my printer not print the requested number of pages?
If it is otherwise working, there is a problem with your printer driver. Go up to the printer manufacturer site and make sure you have the latest printer driver. Or just Google the printer model and the word "driver". sometimes there's nothing to be done if it's a bug in the driver that they no longer support. I have a printer that will not print multiple copies without reloading the printer for each one. It's a driver problem, but HP has stopped updating my driver.
I have a problem with
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Printer is printing the black color as light grey.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Which is best laser pointer for presentation ?
I agreed with Nancy. I was also reading reviews on https://reviewspack.com/best-presentation-clickers/ and https://www.thedailytell.com/best-laser-pointers-for-presentations/ Logitech Spotlight is most powerful pointer the R800
How i can resolve fuser error laser jet pro 400
A fuser error is probably caused by a thermistor (detects an overheating problem). The fuser is probably best serviced by the manufacturer as an improperly serviced fuser could lead to a fire.
Scanner error 6 in laser jet 3052
"Error 6" indicates a common problem with LaserJet, a brand of dry electrophotographic laser printers from computer technology company Hewlett-Packard. One of such machines is the HP LaserJet 3390, an all-in-one printer that can print, copy, scan and fax documents.
