20 Most Recent
Samsung ML-1640 Monochrome Laser Printer Questions & Answers
How to reset ML1640 printer
I dont really understand the question as when you insert a replacement toner it will inform the printer a new toner has been inserted, however if you are refering to Hardware reseting the page count please find a diagram here http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
Samsung 1640
you are filling hp or canon laser printer toner poly bag. It is not this same toner. I have original SAMSUNG,LEXMARK,XEROX toner poly bag
My Email is
[email protected]
Samsung Ml- 2245 chip
You have to check with your toner suppliers, they have chips for toners and drums, nothing in software you can do to get around the chips on a Samsung.
I had purchased a Samsung
call @Coimbatore- 9843035235 printer service, instant repair Help over the phone..9843035235 @ Coimbatore Tamil Nadu
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
