20 Most Recent
Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code Questions & Answers
HOW TO INCREASE PRINTHEAD HEAT
Press Setup/exit first option should be Darkness.
Press Select then the plus key.
Press setup/exit twice to exit and save.
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Zm400 cannot use com1
Use a null modem serial cable . Match computer com1 serial port settings with printer serial port settings.
I cannot print from my
That is correct, you can try VM Windows. I would get a cheap laptop instead, as it is easier. Hope this helps!
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
